shadow Posted March 17, 2008 Report Posted March 17, 2008 Silly Question right? Where is it located on my TGP? Quote
hotrodolds Posted March 17, 2008 Report Posted March 17, 2008 Drivers' side, under the washer fluid container. Quote
jeremy Posted March 17, 2008 Report Posted March 17, 2008 under the winshield washer fluid resevior (sp?) on the driver side of the engine bay Quote
shadow Posted March 17, 2008 Author Report Posted March 17, 2008 Thanks. Wow sounds difficult to get to. Quote
hotrodolds Posted March 17, 2008 Report Posted March 17, 2008 It's a lot more complicated that it needs to be. The diagonal brace comes off, the washer tank comes off, and on a N/A car, the airbox needs to come out, too. I don't know about the TGP. Quote
93CutlassSupreme Posted March 17, 2008 Report Posted March 17, 2008 It's a lot more complicated that it needs to be. The diagonal brace comes off, the washer tank comes off, and on a N/A car, the airbox needs to come out, too. I don't know about the TGP. No it doesn't. Just use a long extension to get the hold-down bolt. Quote
CSI_MuNkY Posted March 17, 2008 Report Posted March 17, 2008 It's a lot more complicated that it needs to be. The diagonal brace comes off, the washer tank comes off, and on a N/A car, the airbox needs to come out, too. I don't know about the TGP. No it doesn't. Just use a long extension to get the hold-down bolt. On mine you have to move the air box about 1" to the side to get the battery tie down off. But it doesn't have to come out of the car. And if the washer fluid bottle is too much for you, you can relocate it or the battery. Jamie Quote
5speedz34 Posted March 17, 2008 Report Posted March 17, 2008 For a TGP: Remove the 3 brace bolts. 3 13mm. The washer bottle is the older style so its not in the way. IIRC, there is a plastic cover for the battery, that is held down by the plastic retaining clips. Remove those. Unbolt battery tie down. 13mm Unbolt battery cables. 8mm Your done! On the later cars you need to remove the washer bottle. Its easiest to pull the airbox to give yourself some room. Quote
CSI_MuNkY Posted March 17, 2008 Report Posted March 17, 2008 Unless Matt did this custom, the washer bottle is in the way. Although smaller than the ones on newer cars, its still over top of the battery. Jamie Quote
5speedz34 Posted March 17, 2008 Report Posted March 17, 2008 Shit I forgot TGP's got a custom washer bottle. 88-91 NA cars got the smaller non-battery covering bottle. Quote
Addicted to eaton Posted March 17, 2008 Report Posted March 17, 2008 Whos BAD ASS TGP MOTOR IS THAT!? Quote
CSI_MuNkY Posted March 17, 2008 Report Posted March 17, 2008 Whos BAD ASS TGP MOTOR IS THAT!? Its Matts (93luminaz34) winner of the 2007 Car of the year award http://www.w-body.com/forum/index.php?topic=65496.0 Jamie Quote
shadow Posted March 17, 2008 Author Report Posted March 17, 2008 Unless Matt did this custom, the washer bottle is in the way. Although smaller than the ones on newer cars, its still over top of the battery. Jamie I could swear the coolant bottle for my 90 TGP is on the lower drivers side not where it is on that car? Quote
shadow Posted March 18, 2008 Author Report Posted March 18, 2008 Yes I just double checked my coolant bottle location is not the same as the one pictured. Is it different from 1989 to 1990 tgp? or has it been relocated in the pic? Quote
mfewtrail Posted March 18, 2008 Report Posted March 18, 2008 Yes I just double checked my coolant bottle location is not the same as the one pictured. Is it different from 1989 to 1990 tgp? or has it been relocated in the pic? That's the washer fluid bottle, not the coolant bottle. The coolant overflow is located just in front of and below the turbocharger on the driver's side. Quote
shadow Posted March 18, 2008 Author Report Posted March 18, 2008 Yes I just double checked my coolant bottle location is not the same as the one pictured. Is it different from 1989 to 1990 tgp? or has it been relocated in the pic? That's the washer fluid bottle, not the coolant bottle. The coolant overflow is located just in front of and below the turbocharger on the driver's side. Yeah but in the previous pic the coolant bottle is on the left top of the engine? Quote
mfewtrail Posted March 19, 2008 Report Posted March 19, 2008 Yeah but in the previous pic the coolant bottle is on the left top of the engine? I blame that comment of lack of sleep! No really, I just wasn't paying attention. That coolant bottle is from a later Grand Prix as the TGP's had the black beauty cover there originally. My 1993 has the same style coolant bottle over there. I believe they were in GP's and probably other W-bodies from 1991 to 1993. Quote
GOT2B GM Posted March 19, 2008 Report Posted March 19, 2008 Thats my TGP. The washer bottle is the original, I upgraded the coolant bottle to the more accessable 91-93 style. Quote
