88red4cyl Posted March 16, 2008 Report Posted March 16, 2008 I ran out this morning on an errand, and I noticed something funny on the car.. The heat setting was blowing cold air.. I turned the controls all the way to the cold side, and the air warmed up a bit.. I switched it back to hot and the air stayed the same temp.. Everything I tried it on, I was getting the same kinda warm air.. Even on the AC settings.. What the heck is going on here? See below for update.. Quote
Fleeingpepper Posted March 17, 2008 Report Posted March 17, 2008 The knobs may be bad. Or a vacuum thingy that other people are having, don't really know that one because I've only seen knobs go bad, once. But the knobs are easy to test. If the fan changes when you turn that knob, take off the knob for the fan and temp; Put the fan knob on the temp knob and if nothing changes that's not the problem. Quote
88red4cyl Posted March 17, 2008 Author Report Posted March 17, 2008 Do the knobs just pull off? Quote
Fleeingpepper Posted March 17, 2008 Report Posted March 17, 2008 I'm not sure. I think they might. The car where the knobs went bad was a Cavalier. If they look near to the picture, then they do. Other people with problems like this the problem was something with a vacuum or something, but if the knobs come of it's easier to test. Quote
88red4cyl Posted March 18, 2008 Author Report Posted March 18, 2008 Ok.. I switched the knobs, and I get the same result.. What else is there to check? Quote
Brian P Posted March 18, 2008 Report Posted March 18, 2008 I bet that's the blend-door motor controller (heat actuator). Look here: http://www.w-body.com/forum/index.php?topic=41201.0 Quote
88red4cyl Posted March 18, 2008 Author Report Posted March 18, 2008 I bet that's the blend-door motor controller (heat actuator). Look here: http://www.w-body.com/forum/index.php?topic=41201.0 Does it matter that it's not the dual climate control setup? I read through it, and I am still kinda confused... So I have to replace the actuator, or is there a way to repair it? Quote
Brian P Posted March 18, 2008 Report Posted March 18, 2008 The regular climate control uses the same part, but just one of them since it's single-zone. I would just try a junkyard one (If anything, get one from a pre-95 as these seem to be much stronger, and should interchange no problem) or a new GM one. I don't know where to find the parts to repair it. Quote
88red4cyl Posted March 18, 2008 Author Report Posted March 18, 2008 Since you seem to be fairly knowledgable on the subject, how involved would it be to convert the car to the dual climate setup (the vertical switches, not electronic)? Is it something fairly simple, or would you not even mess with it? Quote
Brian P Posted March 18, 2008 Report Posted March 18, 2008 without looking at the wiring differences, you'll probably just have to add 3 or 4 wires for the additional heat actuator. You'll also have to take out the dash for the different heat duct box that has two separate "doors" for the air to pass thru the heater core. MAYBE it can be done by just swapping the dual heat duct "doors" to your original box but I haven't looked into that. That will be the biggest obstacle/PITA. Do you like your passengers that much? Quote
88red4cyl Posted March 18, 2008 Author Report Posted March 18, 2008 Do you like your passengers that much? Good point. Thanks. Quote
rockfangd Posted March 19, 2008 Report Posted March 19, 2008 dual climate coud be good for me as i love having the heat cranked but none of my passengers like it lol. Quote
Crazy K Posted March 19, 2008 Report Posted March 19, 2008 Do you like your passengers that much? I think it's a great idea to upgrade. But do I like my passengers that much? No... but I wouldn't mind an easy fuck. Quote
88red4cyl Posted April 9, 2008 Author Report Posted April 9, 2008 This afternoon I decided to tear into the car and get the actuator out.. Kinda surprised by what I found.. The thing looks fine to me... Where should I start looking at now? Quote
Crazy K Posted April 9, 2008 Report Posted April 9, 2008 plug it back in and see if it moves. you don't need to completely reinstall it, just plug it in and change the heat setting. Quote
88red4cyl Posted April 9, 2008 Author Report Posted April 9, 2008 Well hot damn... I put it back together, and it works now... How the heck did that happen...? I should probably replace it anyway though, just to be safe... Quote
bve32k Posted April 9, 2008 Report Posted April 9, 2008 Well hot damn... I put it back together, and it works now... How the heck did that happen...? I should probably replace it anyway though, just to be safe... Where you getting any heat at all? My car only blows heat under acceleration. And then it just blows outside air. Quote
88red4cyl Posted April 9, 2008 Author Report Posted April 9, 2008 Well hot damn... I put it back together, and it works now... How the heck did that happen...? I should probably replace it anyway though, just to be safe... Where you getting any heat at all? My car only blows heat under acceleration. And then it just blows outside air. I was getting semi warm air on every temp setting, even on AC.. Now it works just fine. Quote
Brian P Posted April 10, 2008 Report Posted April 10, 2008 maybe the little piece of plastic that the actuator "Grabs" is loose or stripped or something. Also check to see if the blend door moves freely with your hands (twist that plastic protrusion) Quote
88red4cyl Posted April 10, 2008 Author Report Posted April 10, 2008 maybe the little piece of plastic that the actuator "Grabs" is loose or stripped or something. Also check to see if the blend door moves freely with your hands (twist that plastic protrusion) Yep, the blend door moves freely, I checked it before I put the car back together.. As you can see from the pic, it seemed like there was a lot of grease.. It seemed like the gear coming from the motor and the first gear had so much grease there that it was binding or something (kinda difficult to turn, if it's possible for grease to bind things).. I cleaned some of the grease out of that area, reinstalled it, and presto! it works.. Quote
88red4cyl Posted April 11, 2008 Author Report Posted April 11, 2008 I thought so too.. I'm just glad I have climate control working again!! Quote
