kaptnjack Posted March 12, 2008 Report Posted March 12, 2008 I called all the yards....no luck. Is there a definitive swap that I am overlooking? Quote
93CutlassSupreme Posted March 12, 2008 Report Posted March 12, 2008 Swap in a 125C into that bad boy! Quote
Psych0matt Posted March 12, 2008 Report Posted March 12, 2008 what year? if its before '94, any 3.4 before '94 should have the same tranny, and if you have a '94 or '95, any '94/'95 trans should work just fine. My tranny is out of a 95 GP. As far as I know this is all you need to know, but I did this like 3 or 4 years ago, so I'm not 100% sure any more Quote
93CutlassSupreme Posted March 12, 2008 Report Posted March 12, 2008 what year? if its before '94, any 3.4 before '94 should have the same tranny, and if you have a '94 or '95, any '94/'95 trans should work just fine. My tranny is out of a 95 GP. As far as I know this is all you need to know, but I did this like 3 or 4 years ago, so I'm not 100% sure any more Since when did the 4T60E change? Quote
Psych0matt Posted March 12, 2008 Report Posted March 12, 2008 the gearings were slightly different I think. That's why I said I wasn't sure. It's possible that at the time I didn't know nearly as much as I do now, and figured since the engines were different then the trannys would be too. Gosh, sorry for trying to be helpful, you could have just corrected it Quote
93CutlassSupreme Posted March 12, 2008 Report Posted March 12, 2008 the gearings were slightly different I think. That's why I said I wasn't sure. It's possible that at the time I didn't know nearly as much as I do now, and figured since the engines were different then the trannys would be too. Gosh, sorry for trying to be helpful, you could have just corrected it Sorry, I wasn't trying to be a dick. I just never heard of the 4T60E changing. Thats all. Damn. Quote
Psych0matt Posted March 12, 2008 Report Posted March 12, 2008 it's cool However, why is this in the vert section anyways? Quote
kaptnjack Posted March 13, 2008 Author Report Posted March 13, 2008 Thanks for the responses. I apologize if I posted in the wrong forum. I am rescueing a 93 CS vert and this is the first Olds I have owned since 1980. I am still learning that some of my questions may be more appropriate in other sections and are not vert specific. 1993 CS vert 3.4L 4t60E code CW Quote
Crazy K Posted March 14, 2008 Report Posted March 14, 2008 you will want a 91-93 transmission from a 3.4 car. a 94 or 95 might be usable if you dig some re-pinning, or if you popped the cover and used the harness from the bad transmission in the 94-95 transmission. all the 91-95 3.4 trannies (probably 96 as well) have a 3.43 final drive ratio. the trannies used in 3.1 and 3100 cars have a 3.33 final drive ratio. I do not know if one transmission is stronger than another, or if they can successfully be cross swapped without shift or limp mode issues. yes. this belongs our of the vert section. otherwise... welcome! Quote
ManicMechanic Posted March 14, 2008 Report Posted March 14, 2008 A ---------- CUTLASS 91-92 A.T.; 4T60E (3.4L only) GRAND PRIX 91-92 A.T.; 4T60E (3.4L only) LUMINA CAR 91-92 A.T.; 4T60E (3.4L) B ---------- CUTLASS 93 A.T.; 4T60E, 6-207 (3.4L) GRAND PRIX 93 A.T.; 4T60E, 6-207 (3.4L) LUMINA CAR 93 A.T.; 4T60E, 6-207 (3.4L) C ---------- CUTLASS 94-95 A.T.; 6-207 (3.4L) GRAND PRIX 94-95 A.T.; 6-207 (3.4L) LUMINA CAR 94-95 A.T.; 6-207 (3.4L) MONTE CARLO 95 A.T.; 6-207 (3.4L) 4 speed A.T. 4T60E, M13. |A| thru |C| fit as shown in notes. B ----------- Valve body cover is steel & has no engine mounting bosses . |A| & |C| fit by transferring valve body wiring harness, solenoids & electrical connector in case as needed. Quote
kaptnjack Posted March 14, 2008 Author Report Posted March 14, 2008 Good Information.....thank you. I also googled up.... Here is the interchange for the transmission you are trying to replace in the Oldsmobile: CUTLASS 93 A.T.; 4T60E, 6-207 (3.4L) GRAND PRIX 93 A.T.; 4T60E, 6-207 (3.4L) LUMINA CAR 93 A.T.; 4T60E, 6-207 (3.4L) What that means is that the ONLY transmission that will be a direct-fit for yours will be from either a Cutlass, Grand Prix or Lumina, 1993 ONLY and the vehicle must be equipped with the 4T60E and a 3.4L engine. In the industry we call that a 'tight' interchange because it is a one-year-only part. for what it's worth Quote
patgizz Posted March 14, 2008 Report Posted March 14, 2008 FWIW all 91-93 trannies i've used interchanged with each other with no electrical issues. wiring changed for 94 as well as some other crap(pulse width modulation solenoids and whatnot) which is why the 94-95 units do not interchange. if you plug a 91-93 tranny into a 94-95 harness you get 3rd and 4th gear only and no lockup. Quote
kaptnjack Posted March 29, 2008 Author Report Posted March 29, 2008 Ok....it was decided that a full rebuild of the existing oem tranny was the way to go. The cases have been split and cleaned and the rebuild is complete with the exception of the pump. The pump and impellor chewed itself up and is unusable,,,the pump body and cover are chewed up and junk. (what causes this?) Here's the problem....cant find a replacement pump. The tranny shop has tried every supplier in 200 miles and tried 5 pumps from three suppliers and they are all wrong and nobody can seem to locate the right one. The pump that came out of my tranny has two switches and no bleed valve. All the replacements offered by various suppliers have a bleed valve and the fluid ports/channels are different. The numbers on the oem pump casing halves are 8651507 and 8651508. I am not totally sure becuse a google search offers only a couple of results but....it appears the pump assembly GM part number "may" be 24200574 If I could locate a good pump that would be grat...If I could locate good pump and cover casing I could put a kit in it so...there are a couple of options. Does anyone have any experience with this type issue? Anybody have a source for this part? Any help would be appreciated. Quote
kswiss808 Posted March 30, 2008 Report Posted March 30, 2008 If you don't mind me asking How much is the rebuild going to cost? Quote
kaptnjack Posted March 30, 2008 Author Report Posted March 30, 2008 Well.....it aint over yet. But....the pending quote has been stated as about $1600 includes remove/replace, flush, fluids, converter, hard parts and labor. 12 month 12000 mile warranty Quote
