kfahn Posted July 25, 2003 Report Posted July 25, 2003 ok, what the f''' is this wire, i was inspecting my engine bay, and lo and behold, i find this wire hanging behind everything disconnected! Quote
cutlassdude96 Posted July 25, 2003 Report Posted July 25, 2003 check to see if there is a plug, plug in at the power stearing pump Quote
Guest RedCutlassSL Posted July 25, 2003 Report Posted July 25, 2003 mines like that, robs is like that, all 3100 powered monsters are Quote
kfahn Posted July 25, 2003 Author Report Posted July 25, 2003 there isn't any kind of plug for that to connect to, does anyone know what it can/should connect to? Quote
Brian P Posted July 25, 2003 Report Posted July 25, 2003 that looks like canister purge solenoid wire Quote
cutlassdude96 Posted July 25, 2003 Report Posted July 25, 2003 do you have RPO code NV7 - STEERING , “POWER, VARIABLE EFFORT†Quote
kfahn Posted July 25, 2003 Author Report Posted July 25, 2003 that looks like canister purge solenoid wire i have no idea what that is or what it does Quote
Cledus Posted July 26, 2003 Report Posted July 26, 2003 Mine is like that too. Someone guessed that it was not used in our '95s because they still have an OBD1 computer. In 1996 the OBD2 computer was used and this wire is plugged into something. Quote
rglguy Posted July 26, 2003 Report Posted July 26, 2003 i have a conector that looks like that, it plugs into my MAP, and in that pick i see no conecotion to the MAP its red and blue Quote
ismellrealbad Posted July 26, 2003 Report Posted July 26, 2003 wow, and i thought my memory was bad........who can forget THIS thread that i started? http://www.w-body.com/forum/viewtopic.php?t=5100&start=0&postdays=0&postorder=asc&highlight= well anyways the start of this new thread makes me feel much better about my last unsolved thread about this. i guess dustin is right, all us 3100 guys have some wierd ass useless connector Quote
godofthunder Posted July 26, 2003 Report Posted July 26, 2003 all cept cutlassdude96. I have Variable Effor Steering, but have never noticed that plug. I will have to look for it this morning. Window Sticker also says "Variable Ratio Power Steering" Was it left unpluged from the factory? Wow, i need to go check this out. Jon Quote
godofthunder Posted July 26, 2003 Report Posted July 26, 2003 just looked, i dont see any loose wires anywhere really. And this wire...are you talking about itbeing plugeed into the botom back of the PS pump (or where the fluid goes, below that). Jon Quote
Robby1870 Posted July 26, 2003 Report Posted July 26, 2003 that looks like canister purge solenoid wire Bingo!! Robby Quote
kfahn Posted July 27, 2003 Author Report Posted July 27, 2003 ok, still don't know what a canister purge solenoid wire is Quote
Robby1870 Posted July 27, 2003 Report Posted July 27, 2003 ok, still don't know what a canister purge solenoid wire is Its something for the HVAC stuff. Im not sure what it does, but helps the HVAC stuff out somehow. Wow, that was helpful Robby Quote
brian89gp Posted July 27, 2003 Report Posted July 27, 2003 It is attached to the gas tank vapor canister, it allows the engine to suck in the gasoline fumes under certain engine conditions so that the fumes aren't vented to atmosphere. And yes, that looks to be a CCP plug. Quote
Robby1870 Posted July 27, 2003 Report Posted July 27, 2003 Man, was I off. :oops: Oh well, thanks Brian89gp! Robby Quote
cutlassdude96 Posted July 27, 2003 Report Posted July 27, 2003 its behind the engine by #5 spark pulg near the master cylender. Quote
