outatime Posted March 5, 2008 Report Posted March 5, 2008 I have a 96 regal 3.8 N/A. There are two fuel lines going to the intake. One in the back and one in the front. The one in the back is leaking by where it is clipped on. Does anybody have a part number so I can replace that line? Or if you don't have a part number maybe a suggestion on how to replace it? I know the plastic line connects to the metal line but I'm not sure how to get it off. I did call the buick dealership and they gave me a part number of 10742820. They also said it had been disconnected. Quote
ron350 Posted March 6, 2008 Report Posted March 6, 2008 If it is only leaking at the fuel rail connection you probably just need new o-rings. There are two o-rings in each plastic fuel line fitting so you will need 2 large and 2 small o-rings. The rear fuel line is the supply line and uses the larger of the o-rings in the kit. http://www.partsamerica.com/ProductDetail.aspx?MfrCode=NIE&MfrPartNumber=27478&PartType=1405&PTSet=A Edit:This is the only write up about replacing fuel line o-rings I can find. Your fuel line connectors are plastic and release when you squeeze the two translucent tabs together and pull up on the connector. The translucent retainer stays in the steel fuel line and the plastic connector and line slides off. http://www.clubgp.com/newforum/tm.asp?m=3076805&appid=&p=&mpage=1&key=o%2Dring&language=single&tmode=&smode=&s=#3076805 Quote
88red4cyl Posted March 6, 2008 Report Posted March 6, 2008 I have a 96 regal 3.8 N/A. There are two fuel lines going to the intake. One in the back and one in the front. The one in the back is leaking by where it is clipped on. Does anybody have a part number so I can replace that line? Or if you don't have a part number maybe a suggestion on how to replace it? I know the plastic line connects to the metal line but I'm not sure how to get it off. I did call the buick dealership and they gave me a part number of 10742820. They also said it had been disconnected. This may be a weird question, but is that pulling your fuel mileage down at all? Quote
outatime Posted April 25, 2010 Author Report Posted April 25, 2010 I appreciate the help but this is not what my lines look like. I know you know what they look like judging from your description but the lines in the pictures of the pontiac don't look the same. Quote
BS009 Posted April 25, 2010 Report Posted April 25, 2010 (edited) no, 96 has a series 2. if the lines are anything like the one's on the l27 then you just unbolt them from the fuel rail and there should be another spot further back where you can unbolt it. the lines aren't plastic, they're actually rubber with a plastic piece wrapped over them. the rubber part doesn't come apart from the metal piece that bolts to the fuel rail. I'm not sure if that confused you or not but it sounds like it did. If it's leaking at the connections then replace the o-rings, but if the rubber hose itself is leaking then you need to replace those entire pieces. Edited April 25, 2010 by BS009 spelling Quote
outatime Posted April 26, 2010 Author Report Posted April 26, 2010 no, 96 has a series 2.if the lines are anything like the one's on the l27 then you just unbolt them from the fuel rail and there should be another spot further back where you can unbolt it. the lines aren't plastic, they're actually rubber with a plastic piece wrapped over them. the rubber part doesn't come apart from the metal piece that bolts to the fuel rail. I'm not sure if that confused you or not but it sounds like it did. If it's leaking at the connections then replace the o-rings, but if the rubber hose itself is leaking then you need to replace those entire pieces. OK I'll see if I can get the orings at the dealer. Thanks for the help. BTW nice pickup. I need to find something like that in Dallas Area. Quote
outatime Posted April 28, 2010 Author Report Posted April 28, 2010 no, 96 has a series 2.if the lines are anything like the one's on the l27 then you just unbolt them from the fuel rail and there should be another spot further back where you can unbolt it. the lines aren't plastic, they're actually rubber with a plastic piece wrapped over them. the rubber part doesn't come apart from the metal piece that bolts to the fuel rail. I'm not sure if that confused you or not but it sounds like it did. If it's leaking at the connections then replace the o-rings, but if the rubber hose itself is leaking then you need to replace those entire pieces. OK I tried the dealer and I can't get the o rings by themselves I have to buy the entire line. So does anybody know what size the o rings are ? Quote
BS009 Posted April 28, 2010 Report Posted April 28, 2010 I wouldn't replace the whole piece unless it's in bad shape. I'm not sure on the size, but you should just be able to run to autozone or lowe's or something and pick up a couple of o-rings by themselves. I try to avoid buying anything from the dealer because they're way over-priced. Quote
WrathOfSocrus Posted April 28, 2010 Report Posted April 28, 2010 http://rockauto.com/ AC Delco part #2173366 fuel feed and return pipe O-rings Look up your vehicle and under Fuel/Air there is the fuel rail O-ring kit listed as written above for $1.14 not to be confused with fuel 'injector' O-rings Quote
z0mb1emutha Posted May 6, 2010 Report Posted May 6, 2010 you can replace just the end of the line pretty easily ..lookng at about 8 bucks! Quote
outatime Posted July 3, 2010 Author Report Posted July 3, 2010 you can replace just the end of the line pretty easily ..lookng at about 8 bucks! Where can I get this at ? The dealer only has the entire line. It's been a while since i went up there and priced it but I think it was around $75. Quote
outatime Posted July 7, 2010 Author Report Posted July 7, 2010 Anybody else has this problem? Can you replace the whole line with some fuel injection hose ? Quote
AL Posted July 7, 2010 Report Posted July 7, 2010 You can but I am not sure how... Why not just get the o-rings Quote
outatime Posted July 7, 2010 Author Report Posted July 7, 2010 I tried replacing them with just some generic o rings from the parts store. That worked for a week or so and started leaking again. I ordered the orings through buick and should have them any day. Quote
outatime Posted July 7, 2010 Author Report Posted July 7, 2010 This is not what mine looks like. When I took it apart and replaced it with generic o rings, there were actually 3 of them. One of them was pretty flat compared to the other 2. Quote
xtremerevolution Posted July 9, 2010 Report Posted July 9, 2010 This is not what mine looks like. When I took it apart and replaced it with generic o rings, there were actually 3 of them. One of them was pretty flat compared to the other 2. You ordered them from Buick? Why not from RockAuto? I'll check the pictures when I get home since they're blocked at work so I can give you a hand with this. I've worked on my fair share of L36's and I actually have a 96 Regal sitting in my driveway. Quote
