mixe olds Posted March 1, 2008 Report Posted March 1, 2008 I am in the middle of trying to install a DIS into my 94 cutlass when just checking to see if everything is still alright, no power to the radio & ECC. I see that there is no power to the radio and the ECC when everything else works. You can see the lights in the radio and ECC come one when you turn the head lamps on. I checked a few fuse but I'm not sure if they were the right one or not. I hope there is a simple fix to this I hope that I didn't cut a wire I wasn't suposed to. Please let me know if you have any ideas Thanks Quote
slick Posted March 2, 2008 Report Posted March 2, 2008 Yes, there are fuses for this stuff. Check and replace. If it keeps blowing as soon as you put in a new fuse, i'd check your connections with the DIS. Quote
mixe olds Posted March 5, 2008 Author Report Posted March 5, 2008 I removed the DIS and then check all the fuses in the glove box. Still there is now power to the Radio and ECC. Is there one fuse that controls power to both these units? What specific fuse I need to look at? Or did I cut a wire that I shouldn't have? Quote
rockfangd Posted March 12, 2008 Report Posted March 12, 2008 you may have cut a wire. dont think there is one fuse for just those 2. maybe a short. Quote
