Brian P Posted February 29, 2008 Report Posted February 29, 2008 If you have either of these vehicles, could you supply me with the following? 1- Year/trim level 2- Engine 3- FRONT spring code (found on the spring itself OR on the RPO option tag in the trunk) 4- Any other info you know about the stock suspension (swaybar diameter, etc) Thanks very much! Quote
Brian P Posted February 29, 2008 Author Report Posted February 29, 2008 The front spring ID code is on the last line, and starts with the # 6 (Left front) and # 7 (Right front). In this case it's 6UX and 7UX, the code on the springs would be FUX. Quote
MonteCarloDude Posted February 29, 2008 Report Posted February 29, 2008 as long as its not bad outside in the morning, il head out and grab some pics for you. Quote
MonteCarloDude Posted February 29, 2008 Report Posted February 29, 2008 lots of snow and some ice today, so i cant jack the monte up. but i am going to head down soon and grab those codes for you. Quote
Brian P Posted February 29, 2008 Author Report Posted February 29, 2008 Do you have your original RPO sticker in the trunk? Just grab the code off that, should be easier than trying to find the spring tag (assuming it's still there) Quote
MonteCarloDude Posted February 29, 2008 Report Posted February 29, 2008 wow i somehow missed the part in your 2nd post about the code starting with 6 and 7.... heading back down now to grab those codes. Quote
MonteCarloDude Posted February 29, 2008 Report Posted February 29, 2008 6XT and 7XT, year and trim are in mah sig. as soon as the snow is off the ground il jack it up and grab the front and rear swaybar OD. Quote
Brian P Posted February 29, 2008 Author Report Posted February 29, 2008 no biggie on swaybar OD, my main request was the spring code. Thanks again! Quote
Brian P Posted February 29, 2008 Author Report Posted February 29, 2008 Any other Monte/Luminators around? Quote
Spectrum Posted February 29, 2008 Report Posted February 29, 2008 I'll grab it on my way out to dinner tonight. Horrible weather... Quote
MonteCarloDude Posted February 29, 2008 Report Posted February 29, 2008 no biggie on swaybar OD, my main request was the spring code. Thanks again! no problem, il for sure get the OD when i do my oil, its been about 3000 miles anyways. Quote
5speedz34 Posted March 1, 2008 Report Posted March 1, 2008 I got a set of 96 Monte Knuckles here. I can check if you want me too. Quote
Brian P Posted March 1, 2008 Author Report Posted March 1, 2008 yeah I'd appreciate it, especially if you know it was a 3100 or 3.4X car. Quote
White94GP Posted March 1, 2008 Report Posted March 1, 2008 1. monte carlo 2. 1998 3. 3100 4. 5. ill have look at the stickers once the weather permits but least i got you that info Quote
Chancho Posted March 2, 2008 Report Posted March 2, 2008 1999 Lumina 3100 6py and 7py as far as sway bars, the front is hollow from the side if that helps you, ive herd the 28mm is hollow along with the 34mm Quote
88red4cyl Posted March 4, 2008 Report Posted March 4, 2008 1. 1995 Lumina (base) 2. 3100 3. 6UX & 7UX I'll get the info for the other car when my wife gets home with it.. Quote
88red4cyl Posted March 5, 2008 Report Posted March 5, 2008 1. 1999 Lumina LTZ 2. 3800 Series II 3. 6PY & 7PY Quote
Brian P Posted March 5, 2008 Author Report Posted March 5, 2008 1. 1995 Lumina (base) 2. 3100 3. 6UX & 7UX I'll get the info for the other car when my wife gets home with it.. Are you sure that's a base Lumina? That's FE3/FE9 codes, and normally the LS got that. Maybe it's a '95 thing, lol. Thanks guys. Main thing is I need the front spring codes, the rest isn't necessary. Quote
88red4cyl Posted March 5, 2008 Report Posted March 5, 2008 1. 1995 Lumina (base) 2. 3100 3. 6UX & 7UX I'll get the info for the other car when my wife gets home with it.. Are you sure that's a base Lumina? That's FE3/FE9 codes, and normally the LS got that. Maybe it's a '95 thing, lol. Thanks guys. Main thing is I need the front spring codes, the rest isn't necessary. Unless someone ripped off the LS emblem off, then it's just a stock Lumina (didn't the LS get the tach cluster as well? I don't have those gauges).. FE9 is on the RPO sheet, what's it mean? Quote
Brian P Posted March 5, 2008 Author Report Posted March 5, 2008 FE9 is the sport/touring suspension, basically a continuation of the FE3 suspension but a little softer. It has the 30mm (mid grade) front swaybar, and small rear bar. Some cars like the Cutlass Supreme in '95 got it standard. I know the Regal and I thought the Lumina had it as an option. Did your car come with the 15" steel wheels, or 16" alloys? Quote
88red4cyl Posted March 5, 2008 Report Posted March 5, 2008 FE9 is the sport/touring suspension, basically a continuation of the FE3 suspension but a little softer. It has the 30mm (mid grade) front swaybar, and small rear bar. Some cars like the Cutlass Supreme in '95 got it standard. I know the Regal and I thought the Lumina had it as an option. Did your car come with the 15" steel wheels, or 16" alloys? I've got the 15" steel wheels.. Quote
5speedz34 Posted March 6, 2008 Report Posted March 6, 2008 Forgot about this thread. I'll check in the next week or so. It was off a 96-97 Z34 MC. Quote
