ABS light
Guest RedCutlassSL
Guest RedCutlassSL
that dummy light keeps coming on, what is causing this? i put a new alt and battery in today, so i know it has enough power
Guest RedCutlassSL
also, if there is a problem, what could i pull off my parts car to fix this?
its probably throwing a code. get it scanned even if the light is not on. why its going on and off i dont know. my car used to do this the first few days i had it.......then it just went away. also keep in mind whenever that light it on, the ABS isnt going to function
... my car used to do this the first few days i had it.......then it just went away.
Isnt it funny how GM cars tend to un-fuck themselfs
- Justin
when I had a leak in my brake booster line I my ABS light would come one inttermitently. Might be a good place to check first.
My abs light comes on and goes off...it has a mind of its own. I can't determine what sensor is bad or sensors, but it will go on and stay on when I go over bumps or train tracks to hard!
search this forum and the tgp forum. There is more info than you can absorb.
jud
