I had always had the secondary fan on a switch with no problems. All you have to do is ground the #86 prong on the fan relay. The fan would turn off when the key is off.
Now my problem, I tryed doing this to my primary fan relay using the same #86 prong, but the fan will not turn off when the key is off. So if I leave the switch on by mistake and leave the car, the fan will still be on.
Do you have to use a differant prong on that relay or what?
Thanks
