Dannymik Posted July 23, 2003 Report Posted July 23, 2003 I would like to know what bolt patterns can be put on our W Body vehicles? I believe they have the 5X115 bolt pattern. Would anything else fit...because it seems that most rims I find that I like come with the 5X114.3 pattern :x ! ITs very frustrating Quote
90TGP Posted July 23, 2003 Report Posted July 23, 2003 Yes, our bolt pattern is 5x115. But, 5x114.3 will fit. It won't be an EXACT fit, but they will fit. Quote
GnatGoSplat Posted July 23, 2003 Report Posted July 23, 2003 Even if they fit, the front caliper support bracket may bite you in the ass. Quote
Heza Posted July 23, 2003 Report Posted July 23, 2003 Even if they fit, the front caliper support bracket may bite you in the ass. i hate that bracket with a passion. for 5x115 check: http://www.discounttire.com or http://www.tirerack.com also search Eagle Alloys. they have a few 5x115 wheels. Quote
92turboLE Posted July 23, 2003 Report Posted July 23, 2003 mine were 5x108.... or at least that is what is on the invoice, the back of the wheel, and the tool that was used to measure it... i dunno why it would be different... maybe not stock??? Mine is an ex cop car so i have found all kinds of cool shit and most of the car is GM performance Heavy duty shit... but ii like my wheels, i got them from discount tire factory for $400 with tires!!! the wheels were brand new and the tires (michillen Pilot Sport) had 85% tread left. I Think the total cost was like $460 out the door... cuz the lug nut kit was $40 and then tax. The only reason i got a good deal is cuz they had a set of used wheels, but they wouldnt clear my caliper bracket and i had been waiting there for like 3 hours already, so dude was like since you been waiting, i'll give you new ones for the same price. - Justin Quote
GnatGoSplat Posted July 23, 2003 Report Posted July 23, 2003 Your car is 5x115mm, they don't make hubs in 5x108 that fit. It's possible you could have squeezed 5x108 wheels on there if the bolt holes were big enough, but I wouldn't recommend it. 5x108 is the Ford "small" bolt pattern. I think Taurus/Sable and maybe Contour have that pattern. Quote
Dannymik Posted July 23, 2003 Author Report Posted July 23, 2003 Like I stated earlier...frustration!!! Why do all the ricers get the aftermarket addons? Quote
PJB Posted July 23, 2003 Report Posted July 23, 2003 Check out ebay. Ive seen some cool 17's and 18's with the right bolt patterns. Quote
Dannymik Posted July 23, 2003 Author Report Posted July 23, 2003 I have scoured Ebay and thought about making a bid, but then you go to the fittings charts and they say that it will not fit. Maybe they are going off exact measurements? [/img] Quote
GnatGoSplat Posted July 24, 2003 Report Posted July 24, 2003 I think they're most likely going by caliper support bracket clearance. You'd be surprised how many wheels out there of the right bolt pattern and offset actually WON'T fit. Quote
Dannymik Posted July 24, 2003 Author Report Posted July 24, 2003 That makes sense to me. Does the offset have something to do with the caliper support? What is the rating for the offset? Quote
GnatGoSplat Posted July 24, 2003 Report Posted July 24, 2003 Offset CAN determine whether the wheel will clear the caliper support or not, but not always. Offset is the distance of the hub mounting surface and the center of the wheel. The larger the offset, the more tucked in the wheel will be. The smaller the offset, the more the wheel sticks out. I think the factory 5-stars on the Cutlass are +35mm. The 16" pie-cut wheels on my '89 are +44mm. That would make you think anything from +35 to +44mm would fit, but not so. My new aftermarket wheels are +42mm and they don't clear the bracket at all, but I've heard of some with the same offset that do. I think the only SURE way to tell if the wheel will clear the caliper bracket is to try it. Or if you see another W-body with the wheels you want, that's a pretty good way to tell too! Quote
Sailor77 Posted July 24, 2003 Report Posted July 24, 2003 It is a difficult process. I actually called the man himself.. Boyd Coddington to see what he could do for me. I have him the specs I needed and what the car was and they style I want. It was something like $250 a rim, but would take a month as he had to make them. All in all that isn't too bad. There are a lot of wheels out there for the 97+ GP's. I am gonna to check this winter to see if I can modify my cutlass with that suspension, which is not only better but offers more wheel options. Quote
Dannymik Posted July 25, 2003 Author Report Posted July 25, 2003 what i really want to get is a packaged deal with the tires. I want white rims to match the stripes...thinking that it would go better with my car. The polished rims I have now look good, but I need a change! :shock: Quote
Dannymik Posted July 28, 2003 Author Report Posted July 28, 2003 Anyone have any custom wheels for these series 2 w-body cars?? 1995 Cutlass Supreme Quote
Dannymik Posted July 29, 2003 Author Report Posted July 29, 2003 I like....how much slick94prix? Quote
nerfbars Posted July 29, 2003 Report Posted July 29, 2003 The front bracket does suck! I found that 7/16" wheel spaces with 1/2" longer wheel studs makes about any 5x115mm rim fit just fine. Quote
Baddflash Posted July 29, 2003 Report Posted July 29, 2003 Anyone have any custom wheels for these series 2 w-body cars?? 1995 Cutlass Supreme That should be gen1 not gen2. If it was gen2 you wouldn't have half as much trouble. Anyway it is almost impossible to tell if a wheel will fit unless you test it. I can't tell you how many I have tried with no success. About the best you can do is go to a shop and have them try rims till they find one that fits. I know this isn't anything that hasn't already been said but just wanted to confirm that those front caliper brackets are a bitch and will almost surely spoil any deal you find. Quote
slick Posted July 29, 2003 Report Posted July 29, 2003 I like....how much slick94prix? For the right price, PM me about it. Quote
