For the record, I have a 92 Cutlass Supreme with the 3.4L DOHC. On Saturday morning I checked my oil level and it read below the add line so I grabbed a quart that I had in my trunk and threw it in. I keep every type of fluid in my trunk just in case so it paid off because as soon as I saw it was below the add level I put some more in. That put it just about a quarter over the add line. Then I was busy for the next few days and didn't get a chance to add another one.
Fast forward to today, I went to a car parts store and grabbed a quart and put it in. I ran the car for a few minutes and checked the oil level and it showed a fair bit past the full line. Can this be an issue or is it alright to drive the car like this? And is the reading even accurate? I find it hard to believe that a single quart would take it from 1/4 way between add and full to a 1/4 over full...
Thanks,
Phil
You need to take your measurements when the engine is cold, otherwise, you're not going to get an accurate reading.
Well I just went and checked, about 2 hours after last driving it and it still read that it was overfilled. I touched the engine with my hand though and it was still pretty hot, so should I just wait until the morning and check then? And would I be good to drive it tomorrow if it still is reading 1/2-3/4 a quart too high?
For next time, the rule of thumb is to only add oil if it is a quart low. Otherwise, don't worry about it.
a little under is better than a little over. Thats alot of oil in a week. mine always reads the same whether cold or hot.
For any 3.4 I always make sure to let it sit few minutes to let the oil drain to the crank.
Chris, how are you supposed to gauge a quart?
These motors have a windage tray, so it keeps the oil from foaming, if you do overfill. A little over is not going to hurt anything, now if you are over by more than a quart, you might have a problem. Why are you using so much oil?
Bottom mark on the dipstick is 1 quart low.
Says it right on the dipstick.
Where? I've never seen this before.
So if theres nothing on the stick its only a quart low?
No that means you are VERY low, add oil immediately.
On the dipstick there is a fill mark and a hatched region and a low mark. The low mark is the add 1 quart to fill.
So the bottom of the hatched mark is 1 quart low?
Now that I know the add line means you are a quart low, I was 1 1/2 quart low before and I put 2 in. Which means I'm about 1/2 quart over... meh. Just a stupid mistake, it was cold out and I didn't take the time to check the level after adding the first quart and just threw another in. 1/2 over is not a big deal anyways.
