  • Replies 100
  • Created
  • Last Reply
Top Posters In This Topic
  • 5speedz34
    6
  • slick
    6
  • pwmin
    6
  • ZoomZoomFan
    6
Let's see. The GA doesn't really NEED anything, but it'll get some stuff I'm sure...
- Full Exterior/Interior detail (fresh wax job this spring)
- Power Steering Flush (power steering fluid and brake fluid are the only fluids I haven't changed :lol:)
- Fix screwed up passenger side headlight (its not mounted correctly at all)...I might just replace it, because it's all pitted and foggy and old. The driver's side is practically new (its from an '04 GA) due to a GA/deer accident last year.
- It'll probably need new brakes all around before '08 is done.
Lets see...
Cutlass:
Swap in 3400 engine
finish the enxhaust
swap in front sway bar with poly bushings
put in passengers side wheel bearing
fix whatever else I cant remember right now
Blazer:
rear brake lines
intake gaskets
rear brakes
find and fix bearing noise in rear end
fix rear axle seal
and whatever else it needs
Prix:
Finally get the 3400 parts from Lataya so I can swap the heads/intakes and maybe pull some power from this POS engine.
Wash/wax the entire thing, polish engine.
Completely clean the interior from top to bottom.
Replace rear monoleaf pads with Moog helper pucks
replace front struts/oil
'Vette:
Replace the master cylinder
replace rear brake line splices if they leak
wash/wax/detail
get right window working (regulator replacement)
get driver's seat moving so my grandma can drive it
Sunfire -
Nothing. I guess it could use a set of rear brakes but I'm not sure because I've never pulled the drums.
Cutlass -
Hopefully I'll be dumping this and picking up something else to replace it. Major parts have been failing at an accelerated rate during the last year and it's time for it to go.
Guest BrOnXBoMbAz213
99 Lumina :
Top Swap:
ported and polished 3400 LIM
ported and polished 3500 UIM
ported and polished 3400 heads (have them already)
65mm TB
PCM Tune
FWI
Exterior :
Sideskirts
Interior
nothing aside from sound system.... putting in clarion 3 ways and an 8 inch sub.. have them already
I'm in the middle of mine yet. Though, with the tax return not being anywhere NEAR what it should have been, I'm limited to getting the paint and body work done, and then parking it for now.
For the Lumina:
Paint / Body work all done by meee (Either black, silver, or a color similar to what I have)
Roll inner fender
Shave Chevy emblem from grill
Suspension & Brakes
-Install Lowering Springs & KYB struts with rear coilovers
-Poly Sway Bar Mounts up front
-High Performance Brake Pads on new rotors
-ADDCO rear sway bar?
-Weld on front and rear strut tower bar mounts (and then bolt on sway bar)
New Head Unit (something cheap with 1/8" aux in on the front)
Interior
-New dash pad
-New carpet & floormats for up front
-Vacuum and shampoo the shit out of it
-Paint Wood grain a decent color
...now the interesting thing will be bump this thread at the end of the year to see what people actually follow through
I'd say mine is pretty easily obtainable haha.
20's on a Cobalt?? :skep:
Yeah, I saw pics of 18 inch casinos on a SS and they looked too small.
but here is what it would like:
and with 18s
:thumb: on the 20's over the 18's. But the tires on the picture of the car with the 18's look like its too small. It looks like it has like the same size sidewall as the one with the 20's.
But those are gaudy chrome wheels with rivets/dimples. If you have the wide polished 5 spokes i always see on cobalt ss' then i say keep 'em. Those are among my favorite oem wheels evar made. along with 2 other 5 spokes (both made by volvo)
Crosslaces are pretty good too. but there have been better executions of crosslace style oem wheels than the grand prix ones.
TGP:
Window Tint
New interior carpet
Repair drivers seat
Finish stereo installation
Exhaust
Fix A/C
Repair radiator leak
Relocate stock tranny cooler
Repair/Replace valence
94+ rear brake upgrade w/ parking brake
96 GTP:
Replace dead battery
Put stock stereo system back in
Repair slow leaks in front tires
Sell it
i want to pay off my Regal GS ASAP and sell it for something more interesting....as in an older car with a turbo and 5-speed that is cheap enough that wouldn't require a car loan.
the L67 thing just never caught on with me :( i'd rather have an interesting 1st GEN W or another older Turbo Dodge. i like the Regal and all but i'm just not into it and it feels so boring.
good, then sell it and i will pass my project on to you :lol:
i think my cobalt looks like a toy already w/ the 18s on it. i'm actually thinking about getting 17s for it. :leaving:
I retract my previous statement...20's look good!
i'd hit that. if i were to buy a brand new car it would most likely be exactly that
yes and the new ones are now turbo! 260hp!
Really? Sweet.
They finally dropped the S/C?
The same for the Ion?
Lumina
Rockers
Paint rockers and inside of doors
Install and Powder coat Aweb Sills ( :redface:)
Install GMPP trailing arms
general maint.
Fix cluster
truck
LIFT
Same here. Headlight work and a PS fluid flush and I'm good to go. :lol:
Actually... I could use a PS fluid flush as well. Probably the original 8 year old, 140,xxx mile fluid. Same with the coolant also.
Same here. It was low a couple months ago and we added some, but it was just as old. Hasn't been low since though.
I know the coolant in the GA was the original stuff when I got it, so out it went. The car ran cooler after that too.
Same here. I'm going to do another flush this year... on all fluids. Tranny I'll just drop the pan.
i assume you take it somewhere to flush the ps fluid.
For the Impala,
Front struts and strut mounts
Im taking it to be cleaned inside and out
Coolant flush
ps fluid flush- wheel doesn't like to turn on hotter days
brake fluid- I guess ill just bleed it out a bunch? keep adding new?
new steering wheel
just pm stuff to keep it like new.
