Crazy K Posted February 6, 2008 Report Posted February 6, 2008 the engine is assumed to be an un-rebuilt motor with an actual 225,000 miles on the clock. The motor still works great... but appears to have a blown coolant jacket on the rear headgasket. This is not confirmed yet as to be the source of the leak...... but I did overheat it. WHAT SHOULD I DO? new headgaskets... and let it go? use a steel head headgasket, which is thinner? (unconfirmed, I read this in a post by brian P) stick in 94-95 fulcrum rockers to bump up the rocker ratio from 1.5 to 1.6? stick in LS6 or some such valve springs? Cover it in gasoline, throw a match on it and let it burn? or any combination of the above? seriously, it can;t be that far gone, can it? Quote
19Cutlass94 Posted February 6, 2008 Report Posted February 6, 2008 Use felpro gaskets. The rockers will have to be 96+ for fulcrum roller rockers and you CANNOT use those as your MPFI heads do not have provisions for them. You will have to go with 94-95 1.6 rockers. They are not fulcrum, they are ball rockers. Why the hell would you put in LS6 springs on a stock cam? Theres no need and your wasting your money. Fix it, use 94-95 rockers or buy my 3100 heads and intakes ( which have the fulcrum roller rockers) Quote
ManicMechanic Posted February 6, 2008 Report Posted February 6, 2008 Cover it in gasoline, throw a match on it and let it burn? Quote
wildbill Posted February 6, 2008 Report Posted February 6, 2008 Replace the gaskets and see how it runs, then let it go. Quote
Guest GrandPrixlover1 Posted February 6, 2008 Report Posted February 6, 2008 Cover it in gasoline, throw a match on it and let it burn? Yeah, haven't you heard of w-body barbecue? mmmmm, tasty!!!! Quote
ManicMechanic Posted February 6, 2008 Report Posted February 6, 2008 Cover it in gasoline, throw a match on it and let it burn? Yeah, haven't you heard of w-body barbecue? mmmmm, tasty!!!! Quote
19Cutlass94 Posted February 6, 2008 Report Posted February 6, 2008 >>>>Insert L67 burnt car here<<<< sry had to Quote
Crazy K Posted February 6, 2008 Author Report Posted February 6, 2008 I'm hoping Brian P might pop in for a few questions.... Quote
Crazy K Posted February 6, 2008 Author Report Posted February 6, 2008 ^^^ doesnt trust us anymore Quote
jeremy Posted February 7, 2008 Report Posted February 7, 2008 i'd personally pull off anything that I would like to keep then send the pos to the yard Quote
Crazy K Posted February 7, 2008 Author Report Posted February 7, 2008 i'd personally pull off anything that I would like to keep then send the pos to the yard I have a complete parts car for it... but with a 4.5 engine so that won't fly. It is getting fixed, eventually. It came to mind.... that I have the 91 vert's 3.1 which is going to go into deep storage once I pick up the tgp motor that will sub for it. I could pull that in five minutes... after all it has no tranny attached. I could do a tear down and inspection... regasket it and speed swap it in a day a few weeks from now. or I could regasket the motor in car and see if it flies. Quote
Robby1870 Posted February 7, 2008 Report Posted February 7, 2008 you could go with iron head 3.1L head gaskets, they are 0.020" thinner, so it'll bump compression just a hair. Quote
Crazy K Posted February 7, 2008 Author Report Posted February 7, 2008 you could go with iron head 3.1L head gaskets, they are 0.020" thinner, so it'll bump compression just a hair. Thats What I read!!! I phone tagged brian, as I think he did it... I'm wondering if I should bump up the compression or not... I need to figure out what mod to do vs not do etc etc Quote
rockfangd Posted February 7, 2008 Report Posted February 7, 2008 Cover it in gasoline, throw a match on it and let it burn? Yeah, haven't you heard of w-body barbecue? mmmmm, tasty!!!! lol. that would be more screwed up than the trashed grand prix last year Quote
1QUICKHATCH Posted February 7, 2008 Report Posted February 7, 2008 I have some mild ported 3.1 heads, milled, with 3angle valve job that I would let go for $400 (+shipping) Use them with the iron head gaskets and it will give that 3.1 a nice kick! If your looking for more than just a nice kick then send me a PM! Quote
Addicted To Boost Posted February 7, 2008 Report Posted February 7, 2008 Fix it and run it forever. 2.8s and 3.1s run forever..and ever Quote
ManicMechanic Posted February 7, 2008 Report Posted February 7, 2008 Fix it and run it forever. 2.8s and 3.1s run forever..and ever Like the Energizer Bunny. Quote
93CutlassSupreme Posted February 7, 2008 Report Posted February 7, 2008 A GM product will run poorly long after most other cars would have stopped running altogether. Quote
Crazy K Posted February 7, 2008 Author Report Posted February 7, 2008 I have some mild ported 3.1 heads, milled, with 3angle valve job that I would let go for $400 (+shipping) Use them with the iron head gaskets and it will give that 3.1 a nice kick! If your looking for more than just a nice kick then send me a PM! nice offer, but I'm too cheap. sorry! A GM product will run poorly long after most other cars would have stopped running altogether. now... this makes me laugh!!!! pensive.... I need to dig in and see what I find. Quote
Brian P Posted February 8, 2008 Report Posted February 8, 2008 If it were me, the 225k engine would be fully rebuilt. I couldn't justify doing head gaskets and nothing else with that mileage + the few cases of overheating, I think you'd be taking a risk. If I were selling the car, that's one thing but if it's mine, I'd freshen it up. Or just put in a Crane H-260, 1.6 rockers, LS6 springs (here you'd need em) and see how long the bottom end lasts (I'd have to have a lot of spare time for that one) Quote
Crazy K Posted February 8, 2008 Author Report Posted February 8, 2008 I still would like to talk to you on the phone Brian. I am not worried... I will have enough bottom ends lying around in case one spins a bearing or something. I will have the 91 verts and the 91 sedans in the garage. and yes... I think I will sell the car once it is restored. clean title.... clean the car... and let it go. Quote
Brian P Posted February 8, 2008 Report Posted February 8, 2008 I usually don't have any alone time at work except about a half hr after lunch. Are you available at like 1:30 tomorrow? Quote
ManicMechanic Posted February 8, 2008 Report Posted February 8, 2008 I usually don't have any alone time at work except about a half hr after lunch. Are you available at like 1:30 tomorrow? Prepare at least 4 hours for Ken... I've been too busy and/or too exhausted to call him... Quote
