Heza Posted July 21, 2003 Report Posted July 21, 2003 can someone explain this to me? whenever i drive my car and hit a little bump, or something that is just a little jolt, my rear end makes a light clunking noise. however, when hitting bigger bumps, it doesn't make that same noise. could this be strut failure or strut mounts going bad? any opinions would be swell. i can't see any problems and am lost! HEEEEEEEELLLLLLPPPPP! Quote
Robby1870 Posted July 21, 2003 Report Posted July 21, 2003 Eh, my car makes noises over bumps, and has for the past 3 years. These cars are old, they are supposed to creak and pop and do other stuff. I wouldnt worry until your leaf spring breaks in half or strut breaks, then I would replace it. You could replace it now and the noise still be there b/c thats just the way it is. JMO Robby Quote
Guest RedCutlassSL Posted July 22, 2003 Report Posted July 22, 2003 who cares if they kinda old? i hate that shit Quote
Heza Posted July 22, 2003 Author Report Posted July 22, 2003 thanks for the advice everyone. appreciate it. guess i'll just wait for my tax return (just filed it a couple weeks ago cause i was deployed) and hook myself up with more suspension goodies. Quote
blugp96 Posted July 22, 2003 Report Posted July 22, 2003 the EXACT same thing is happening to me. I have been told it is the strut mounts, but it is always best to replace the struts as well. So that's my advice Quote
The Burning Rom Posted July 22, 2003 Report Posted July 22, 2003 Heza, I saw you made a comment on ClubGP about the Addco bar. If you have the bar installed, that could possibly be what's doing the clunking. I know others have had clunking issues with it as well. There are a lot of things on these cars that can sound like struts going bad. The mounts could possibly be bad...or the leaf spring bushings...or even the swaybar bushings. But I'd check the addco bar first...if you have it Quote
Heza Posted July 22, 2003 Author Report Posted July 22, 2003 Heza, I saw you made a comment on ClubGP about the Addco bar. If you have the bar installed, that could possibly be what's doing the clunking. I know others have had clunking issues with it as well. There are a lot of things on these cars that can sound like struts going bad. The mounts could possibly be bad...or the leaf spring bushings...or even the swaybar bushings. But I'd check the addco bar first...if you have it i do have the ADDCO bar and it did clunk for a while when i first installed it. however, i called the company up and told them i could use some spacers for where it mounts to the front of the strut. they sent them and ended clunking until i made a 800 mile drive to my parents. then it started making noise again, but it was just because one of the hanging brackets had come loose a little bit. tightened it up, and it was gone again. however, it still makes a slight noise when hitting little bumps. i've looked underneath and the ADDCO bar is not coming in contact with anything whatsoever. thus, narrowing it down to struts/strut mounts. oh....leaf spring bushings are in great shape. Quote
paulo57509 Posted July 23, 2003 Report Posted July 23, 2003 can someone explain this to me? whenever i drive my car and hit a little bump, or something that is just a little jolt, my rear end makes a light clunking noise. however, when hitting bigger bumps, it doesn't make that same noise. could this be strut failure or strut mounts going bad? any opinions would be swell. i can't see any problems and am lost! HEEEEEEEELLLLLLPPPPP! It's the strut mounts up on top. There's a TSB regarding this "problem". If I come across my old invoice, I'll post the part numbers. Quote
Heza Posted July 23, 2003 Author Report Posted July 23, 2003 can someone explain this to me? whenever i drive my car and hit a little bump, or something that is just a little jolt, my rear end makes a light clunking noise. however, when hitting bigger bumps, it doesn't make that same noise. could this be strut failure or strut mounts going bad? any opinions would be swell. i can't see any problems and am lost! HEEEEEEEELLLLLLPPPPP! It's the strut mounts up on top. There's a TSB regarding this "problem". If I come across my old invoice, I'll post the part numbers. thanks paulo57509....however, what is TSB? Quote
Heza Posted July 23, 2003 Author Report Posted July 23, 2003 oooh gravy. thanks. is there somewhere i can read this Technical Service Bulletin? i'm probably just gonna order new strut mounts when i order my new struts. Quote
rglguy Posted July 23, 2003 Report Posted July 23, 2003 when i get my all data back online, ill get you the tsb if its on there, which it most likely is, its got em up to 2000 Quote
optimusprime Posted July 24, 2003 Report Posted July 24, 2003 Are strut mounts hard to change? My '91 is making some stut noises but I can't afford to take it anywhere yet. Quote
SleeperRed90TGp Posted July 25, 2003 Report Posted July 25, 2003 Robby, I love your analogy. Mine has been doing it for at least 10 years. It's the strut rubber on top of the strut. So what. Jud Quote
