Euro34 Posted July 20, 2003 Report Posted July 20, 2003 Hi I have a question about the undrehood fuses for a lumina 3.4. What fuses are supposed to be missing in the fuse box by the coolant overflow tank? Same question for the fuse box over by the battery. thanks Glenn Quote
Robby1870 Posted July 20, 2003 Report Posted July 20, 2003 It all depends on the options the car has. The cover for it should tell you what each place is for. I think all of the 60A fuses are used, maybe wrong though, since they dont tell you what they are for Robby Quote
mfewtrail Posted July 21, 2003 Report Posted July 21, 2003 As Robby said, it lists them on the cover....maybe yours is dirty or something? Check out your RPO sticker in the trunk on the spare tire cover and then compare those "rpo codes" to the ones on http://www.w-body.com and you should be able to discern which all options you have and see if all your fuses for each function are being used. Quote
