So i will be upgrading to a 17" rim in the spring. Right now i have 16's with a 225/50/16 tire. How wide can i go on the 17'' rim? 245/45/17 is what i was thinking. Any ideas?
how wide will your 17's be? Width of a tire is also dependent on width of the rim.
werd.
Sorry they are 17x7
Edit- I have been doing some research on widths.
It looks like a 225 tire is 8.8 inches wide. 235 is 9.2 inches and 245 is 9.6. Can i go up to a 235?
I've got 235/55/16s on 16x6.5 rims right now, with no issues, so 235 on a 7" wide rim would be okay. I'm sure some guys are running 245s on 7" wide rims.
If i could run 245's that would be sweet. Hopefully somebody will chime in here.
Ya, what they said.
The previous owner of the GP put on 245/50 and those tires bulge badly, just trying to fit into that narrow of a wheel.
It sucks too because the car rides like a pogo stick.
waht would you guys say would be the widest tire you could fit on an 8" rim?
255. at that point i'd check for tire to inner wheel well clearance when thay are turned all the way.
I doubt you could fit a 255 on a w-body and it look good. That is a hair over 10 inches wide.
