hwy guys what would be the widest rim and tire combo i could put on my cutlass that wouldnt require spacers and wouldent rub?
GIVE ME YOUR OLD RIMS. (if you do upgrade)
has anyone tried gp crosslaces on a cs?
Yeah, Josh(turbosedan) had a set on his Turbo CS. And I've seen other's with the gp wheels also.
duh. should i try crosslaces?
Factory Grand Prix Crosslace rims are 8" wide and came with 245/50/16 tires.
factory tires are 225/60/16 on my 94, but those 245/50 will fit, I think that is what aweb has, not sure.
93 and older models got the 245/50/16, 94-96, for some reason went to a 225/60/16. Mine currently has the 225/60, but in the spring I will be switching to 245/50. Hopefully there isn't too much difference in my speedo.
Jamie
245-50-16 Goodyear Eagle F1's on x-laces
so i take it an 8" rim is the widest rim i could go?
what size tire are you looking to run?
i dunno yet im more worried about widest RIM
I can read for comprehension so I understand that you are asking about the widest rim, but unless for some strange reason you are wanting to run 265s or wider you shouldn't need anything wider then 8"
reason being im looking into some 19" konig rims but the guy from the manufacture says they only make the 19's with a 8.5" width and is saying that wouldnt work for my car
if he is saying they won't fit, the problem is probably the width combined with offset
so you're looking for a rim for your motorcycle?
wheels = automobiles
rims = motorcycles
looks like a 38-42 mm offset would work.
I have 20" wheels that are 8.5" wide it just depends on the offset of the wheels but im not sure what my offset is sry. 8.5" wide will not rub with correct offset though
  • 3 weeks later...
this was what i was looking at but what this site says and what the guy says is :exclaim: :eek: contradickting :exclaim: :eek:
:lol: :burnout:
It's not like I don't have a set of TGP rims to put on the cutlass... :lol:
Hot.
/thread
