hard to start 3100
damn 3100,
the car runs kinda just tryin to make her to my buddys shop where i can put a new engine in.
here is the problem
when i crank her she sputters and if i pump the gas she will sputter quicker and then take and run but if i turn it off and try to start it back up she wont go like it has no spark or no gas try'd changing tps,map,aic,coil's/whole setup,spark plugs
thx
tows suck soo u know 150 for a tow is bs
Are you sure there is no spark? Otherwise I would say it sounds like a fuel issue if the car is sputtering and it sputters faster when you give it gas. I would guess from what you described that you may have a clogged fuel filter and/or problems with one or more of your fuel injectors.
I don't understand the problem.
You're just trying to get the car to a shop. You can get the car to start and run. That's all you need to get to one place.
To determine if this is a fuel problem spray starting fluid into the throttle body while cranking the engine. If it starts then you obviously have a fuel problem.
