I want to replace the mirrors on my 93 lumina z34
Like the looks of the 97-03 grand prix mirrors will they fit with out
major mods plmk thank you john
thats not what he asked, You best bet is to take yours apart and make a template and go to a JY and find out.
The Junk Yards usually have a never ending amount of Luminas. Any 90-94 Luminas mirror would fit. They are all black plastic. should run you about $12.00 or less a piece.
I would think they would mount the door just fine, but I couldn't imagine that the mounting plate would match the shape and profile of the OEM mirror you wanted to replace. Beside, those mirrors housing is so rounded and too smooth to fit an older GM body style and design. I wouldn't think it would look right even if the mounting plate did bolt up tightly. Two completely different looks. Did you want to know because you want powered mirrors? I think thats his real conquest here. Then you should retro fit the newer mirrors mechanicals into an older mirror housing or just switch out the mounting plate from one mirror to the other. Let us know how it comes out!
You would need custom work, I wouldnt mind doing it either. If your going that far, it would be a good time to think about putting the light signals in the mirror or on the casing.
