98 Regal LS Help
Addicted To Boost
My dad just got a 98 Regal LS with 257,000 Miles on it for free from my neighbor, it runs and drives pretty decent and I have personally helped my neighbor work on it several times, so its very well maintained.
It has the (Series II) 3800 N/A in it also.
What are some things to watch out for in this car? I know very little about the second gen W's besides the work I have helped my neighbor do on it.
Series II 3800...Plenum...Otherwise it'll likely go another 257,000 with regular maintenance.
How do you disable DRL on this car? My dad hates it and wants it off.
Thanks
Hopefully it works the same way on the Regal as that MC... http://www.w-body.com/forum/index.php?topic=24494.0
In that thread, I found a quote from "white93Z34" that hit the nail on the head!
"as far as being seen at night, i'd say that haveing autoheadlights could be dangerous, for example i don't believe auto headlights turn the taillights as well, i could see that as a very bad thing."
THAT is exactly what happened to my dad, he was driving home last night and started the car, noticed the headlights were on and his dash lights were on, so he thought he had already turned on his headlights. Someone almost hit him, because with the DRLs, your taillights don't turn on! WOW DRLs are stupid.
Well apparently Regals are different.. I pulled the left side cover off the regal (which is different than the one pictured in the link) and there is no heat sink or wire harness in there.
How do I disable DRL on the Regal?
Thanks
You could always pull the DRL fuse. I did that on my GP and it disabled the DRL's and automatic headlights that turned on at night. Now I just flip the switch manually.
And watch and be sure that the LIM gasket is good. Those go on probably 99% of the L36's that I've seen, and maybe the trans? The non-HD trans' seem to go quicker than the HD ones. But if they're both good then the car should be a nice DD
Where is the DRL fuse? The car doesn't have an owners manual.
The car seems to run great for the miles on it. Engine and trans are very strong. All the miles on this car are highway miles (my neigbor is a trucker and used it to drive to work and back everyday.)
Thanks again
Yeah, I'm not 100% sure where the fuse box is on Regals, but on my car you open the glove box and on the right side there is a little plastic piece you pull off, and it reveals the fuse box. On that piece of plastic there is a diagram on what all the fuses are. DRL should be one of them.
The fuse box was in a different spot than you described, but I found it. So far, so good, the DRL and auto lights don't work.
Boo, I wasn't sure if it was in the same spot or not. At least you found it!!
That's odd. On my 99' when the dash lights come on that means the headlights/tail lamps kicked on. I thought all 2nd gen Regals were this way..
Hm.. My 99 LTZ is the same way... I thought that's how the autolight system worked...
