Guest GrandPrixlover1 Posted January 20, 2008 Report Posted January 20, 2008 Whenever I park my car on an incline and I put the car in park my car can roll quite a bit before it stops. I was wondering if this was due to a failing parking pin in the transmission, or is it more sinister than it really is. I can just picture hearing something pop/break off in the transmission, EEEEEK!!! I'm just wondering, and I don't want to take my car to a transmission shop. I've heard the horror stories i.e.: go into shop and they say that you have metal shavings in your transmission pan, only to your knowledge when you checked the pan before you went to the shop there were no metal shavings there. hmmmm.... kinda makes ya wonder. but I'm asking here first because I want to put off going to a trans shop if avoidable. 8-) Quote
ManicMechanic Posted January 20, 2008 Report Posted January 20, 2008 How far does it roll? I generally use the parking brake when on an incline anyway... Quote
Guest GrandPrixlover1 Posted January 20, 2008 Report Posted January 20, 2008 at least a good foot or so, but it's just when it comes to a stop so abruptly, it feels like if it continues that somethings gonna break off. and sometimes it happens on shallow inclines as well. I'm just wondering if it's normal for this to happen. Thanks Quote
ManicMechanic Posted January 20, 2008 Report Posted January 20, 2008 Yes, it is normal, but it's not good for it. Try to use the parking brake more often. Quote
Guest GrandPrixlover1 Posted January 20, 2008 Report Posted January 20, 2008 Thanks man. 8-) Yeah and I've started to use it more often, I just got to get used to using it LOL. I also had to get used to using an automatic shifter on the floor. I kept putting my right hand up to the steering column to shift the car, and i'm like "duh you idiot, it's on the floor not on the column", I can be so silly sometimes. Quote
ManicMechanic Posted January 20, 2008 Report Posted January 20, 2008 I know that well...My other ride is an Olds Silhouette with column shift...I'm either grabbing air on the floor in the van or air on the column in the car...LOL! Quote
1990lumina Posted January 20, 2008 Report Posted January 20, 2008 Could bw wrong engine mounts that could cause movement as well. Quote
Dark Ride Posted January 20, 2008 Report Posted January 20, 2008 just hold the brake a little and let it back down slowly after you put it in park otherwise I'd bet its not too good for it. Quote
Chancho Posted January 21, 2008 Report Posted January 21, 2008 its not good at all to do that to a car, and if that parking pin does break you will definatly need a tranny rebuild, its always good to use ur pk brake in the car all the time incline or not, u never know when someone could hit ur car when ur parked and thats it u need a tranny rebuild Quote
GtipGary Posted January 25, 2008 Report Posted January 25, 2008 Now correct me if im wrong (most likely wrong) but shouldnt the linkage pop when someone hits you instead of your trans getting screwed??? Quote
Regal_GS_1989 Posted January 25, 2008 Report Posted January 25, 2008 I would think that if someone hits your car har enough while parked that would require a tranny rebuild, you'd have bigger things to worry about then the tranny. Quote
Chancho Posted January 25, 2008 Report Posted January 25, 2008 nope it doesnt give, have you ever watched movies of the repo guys taking cars back sometimes they have to drag a car out of a driveway, and if it hsappenes to be parked in forward and front wheel drive, they have to drag it out, and all you hear is the dires just sliding on the ground, worst thing for a tranny, with the ecception of a neutral drop Quote
AWeb80 Posted January 26, 2008 Report Posted January 26, 2008 I generally use the parking brake when on an incline anyway... me too. I hate having to yank it out of park if it is wedged too hard.....I always use the brake. Quote
ManicMechanic Posted January 26, 2008 Report Posted January 26, 2008 I generally use the parking brake when on an incline anyway... me too. I hate having to yank it out of park if it is wedged too hard.....I always use the brake. Plus if you don't use the brake, your rear calipers will freeze. Quote
AWeb80 Posted January 26, 2008 Report Posted January 26, 2008 I generally use the parking brake when on an incline anyway... me too. I hate having to yank it out of park if it is wedged too hard.....I always use the brake. Plus if you don't use the brake, your rear calipers will freeze. I thought that was on 88-90...or 88-93 cars.... Quote
ManicMechanic Posted January 26, 2008 Report Posted January 26, 2008 Anything with 4 wheel discs. Quote
wildbill Posted January 26, 2008 Report Posted January 26, 2008 Anything with 4 wheel discs. X2 Using the e brake often readjusts the rear calipers. Which is needed esp on GMs. Quote
ManicMechanic Posted January 27, 2008 Report Posted January 27, 2008 Well, except for older Corvettes and newer Silverados with the e-brake inside the rotor hat... [me=ManicMechanic]is the grandson of the man that invented that set up.[/me] Quote
spiderw31 Posted January 27, 2008 Report Posted January 27, 2008 Well, except for older Corvettes and newer Silverados with the e-brake inside the rotor hat... [me=ManicMechanic]is the grandson of the man that invented that set up.[/me] And the GTOs... they use that setup too. Quote
