hoodilio Posted July 19, 2003 Report Posted July 19, 2003 I really want to complete my suspension component upgrade on my 1993 cutty coupe. Right now i have stock everything and a strut tower brace from a 1994 cutty convertable. I am thinking about going with the front Suspension Tech lowering springs up front and also some Monroe Sensa-Trac cartriges up front. And in the rear put some Monroe Reflex struts with the stock spring. Wat do you guys think, think it will ride good, and yes i know most of you recomend the GR2's. Quote
hoodilio Posted July 19, 2003 Author Report Posted July 19, 2003 Does anyone have any thoughts/ideas. Quote
Redfox340 Posted July 20, 2003 Report Posted July 20, 2003 If you lower the front, you'll want to lower the rear (depending on application). Monroe's are good; keep away from the Gabrials. What are wanting to do with upgrades handling capabilities? Autocross? Everyday drive? Hill climbs? Those choices will effect part selections. - Erik Quote
Gearhead43 Posted July 20, 2003 Report Posted July 20, 2003 I have, KYB GR2 all around Addco Sway bar on rear Polybushing I will have in the near future ST Springs (Front) F-Brace (GMPP Strut bar) Quote
hoodilio Posted July 20, 2003 Author Report Posted July 20, 2003 I want the upgraded handling for hard street driving, so i don't want it to be too rough of pot-holes, but at the same time i don't the rear to drop down soo much when i slam on the gas. Also my rear is already lower then the front by an inch because i have a system in the trunk, so i don't really want to lower the rear. Quote
Gearhead43 Posted July 20, 2003 Report Posted July 20, 2003 Do you already have the FE3 sway bar (34mm) up front? Quote
LukeZ34 Posted July 20, 2003 Report Posted July 20, 2003 Just a fair warning.. Some of us who installed the ST lowering springs noticed a fair amount of 'bounce' in the front end afterward. My lumina was horrible at this, mainly because of the stock struts w/ 100K on them. I have talked to others who have replaced their struts with all new KYB's and they still report some bouncing in the front end with the ST springs. Aside from that, their a good investment. Gives the car a good stance, or levels it out if your rear is sagging from a worn out mono-leaf. I just made a front strut tower brace for the TGP yesterday, and am thinking of fabricating a rear one sometime in the near future as well. I've got KYB's in all 4 corners, Addco rear sway bar, and a front strut tower brace and the car handles like it's on rails (the fat 245/50 tires help as well). Quote
hoodilio Posted July 20, 2003 Author Report Posted July 20, 2003 I have a Sway bar up front but i don;t know if it is the FE3 bar. Quote
Gearhead43 Posted July 21, 2003 Report Posted July 21, 2003 What model and Trim line do you have? Quote
hoodilio Posted July 21, 2003 Author Report Posted July 21, 2003 1993 Cutlass Supreme SL Coupe with the 3100 SFI V6. Quote
Gearhead43 Posted July 21, 2003 Report Posted July 21, 2003 umm ok I doubt you have the FE3.. you probably have the FE1 or the FE2.. HEY SHAWN LIN!! Help me out here a second.. you are the expert on the cutty!!! Either way I think a FE3 34mm bar and mounts will help you alot.. You can even use the 97-98 Lumina Police Package (LPP)bar (same 34mm ) Quote
Brian P Posted July 21, 2003 Report Posted July 21, 2003 1993 Cutlass Supreme SL Coupe with the 3100 SFI V6. Thats a tough one, cause 3100 cars should have the big bar up front. your 93 3100 is a rare one. Check your parts sticker in the trunk for FE something Quote
Heza Posted July 21, 2003 Report Posted July 21, 2003 1993 Cutlass Supreme SL Coupe with the 3100 SFI V6. Thats a tough one, cause 3100 cars should have the big bar up front. your 93 3100 is a rare one. Check your parts sticker in the trunk for FE something i believe i have the 34 mm on my 3100 GP. actually, i'm pretty etched in stone on that one. Quote
GnatGoSplat Posted July 21, 2003 Report Posted July 21, 2003 umm ok I doubt you have the FE3.. you probably have the FE1 or the FE2.. HEY SHAWN LIN!! Help me out here a second.. you are the expert on the cutty!!! Either way I think a FE3 34mm bar and mounts will help you alot.. You can even use the 97-98 Lumina Police Package (LPP)bar (same 34mm ) I think SL's have FE3, but it's hard to say. The 34mm bar on 3.4 DOHC's (and all B4U GP's) and the police bar are one and the same. A 3100 Cutty would NOT have a 34mm bar, FE3 or not. The 34mm bar only came on 3.4 DOHC cars and B4U GP's with any engine, but GP's are the exception. Quote
Black90Euro Posted October 24, 2003 Report Posted October 24, 2003 Hey I've been reading this thread because I need new rear struts , my car has F41 suspension :shock: See Here ----> http://community.webshots.com/photo/15976427/64715455LpEIZS the car has 60706 as of today should I replace all four or just the Rears and what should I get to keeps the same Stiff ride and handling as now KYB 2's ? , the rear seems to be kinda bouncy. before it couldn't be pushed down now it can and then bounces a couple of times. I noticed when I had it inspected that when the guy drove it in the shop when he hit the gas the car squated quiet a bit too.. :? Thanks for the help.... Mark Quote
Gearhead43 Posted October 25, 2003 Report Posted October 25, 2003 I'd go with the KYB GR2.. I think they are the best you can buy for your W-body!!! Quote
sonyman87 Posted October 25, 2003 Report Posted October 25, 2003 I got my KYB gr2s in the mail this week. Boots and mounts aswell. They are going to be installed next saturday. tirerack.com had cheeper prices then the local kyb dealer. about 15-20% cheeper. Quote
