L44 cam
Mr_Efficiency
I was looking around at the factory specs and found that the HO 2.8 in the fiero's used a better cam than the regular 2.8/3.1 and its also the same cam used in the 3.4 that came in the camaro/firebirds.
anyone know anything about this cam? is it much better than the 2.8/3.1 cam? anyone running it?
thanks
thanks
Not sure of the specs, but IIRC, the gen 2 60*V6 uses roller lifters, but I know the gen 1 2.8 used flat tappett lifters. If that is the case, then the cam wouldn't work, as far as I know.
If I'm wrong about this though, then just ignore the post :lol:
Either way, I'd have to go look through my Fiero enthusiast book to find the specs... I'll post them when I get home this evening...
Ok, so my Fiero book didn't list all the specs, but after a little digging this is what I've found. I'm not 100% sure on these specs, but they look right as far as I can tell...
Duration at .50= Intake-196 exhaust-203
Max lobe lift at .50= intake-.263 exhaut-.273
Lobe seperation=109
Lobe seperation=109
If that's right, then the cam is the same as the Gen II 3.1 liter(.2626 intake/.273 exhaust...the intake lift above is just rounded).
Ok I got this from one of the guys over on PFF:
Stock 2.8L Cam
Lobe Lift:
Intake = .2626" Overall lift with 1.5 ratio rocker arms = .3939"
Exhaust = .2732" Overall with 1.5 ratio rocker arms = .4098"
Install valve spring height = 1.575"
BTDC = -14.0
ABDC = 30.0
BBDC = 27.5
ATDC = -4.5
It is a flat-tappet, You cannot use roller lifters.
Just out of curiosity, what would the final ratio or whatever be on a stock cam with a 1.6 ratio rocker? I'm clueless on figuring that stuff out, lol
thanks
thanks
The total lift would be .420 on the intake, and .437 on the exhaust. Just FYI, to calculate the total lift, you multiply the lobe lift by the rocker ratio.
^^^What he said. I run the 94-95 1.6 ratio rockers in my TGP & SE. In my NA engine, there seems to be a little difference in highway throttle response, but I could be imagining things. Desktop dyno estimates were somewhere around 2hp when going from the stock to 1.6 ratio. :lol:
thanks for the info guys.
I have a set of 1.6 roller rockers but i'm going to find a set of 1.6 non roller so i can use my stock pushrods, I dont see it worth the hassle of custom length pushrods to run the rollers just to gain maybe 2 hp. plus its just cheaper to stick with non roller cause its all GM parts nothing aftermarket.
big benefit of roller rockers is less friction which improves horsepower, mpg and allows the engine to rev higher.
I dont know how much of a difference you will see, but there is a difference between roller and non
