Hey y'all.
I just picked up a 1992 Z34 5 speed and it has a problem with it idling high when it's first started (around 2000-2500 rpm). The Service engine light is on when it revs high as well, but goes off when the rpm's go down. I have a buddy who says that it could be the idle air unit. I thought it might be that or the pressure switch. Should I change both to be sure?
Thanks in advance.
Pose
could also be a coolant temp sensor out of range. That will cause the same type of symptoms
Just wasn't sure if it was 1thing or several possibilities. Looks like I'll need to run to autozone. They'll scan it for free for me.
autozone will scan OBDII, yours is too old and is OBDI....use a paperclip....
The Check Engine light will flash.
Oh thanks, and then you just count how many times it flashes to find the code?
I checked the codes and all I get is 12, nothing else. Plus it's not idling high any more. Guess I'll just have to be ready when it does again.
the high idle is very likely to be the LIM gaskets as well.
x2
you'll notice this a lot more when it's colder out. The gasket leaks while it's cold and brittle, until it warms up and seals better.
That's correct. :cool:
  • 1 month later...
What are LIM gaskets?
thanks
thanks
Lower intake manifold
