joeld Posted January 14, 2008 Report Posted January 14, 2008 Almost 2 years to the day I've got to replace gaskets. Looks like a small coolant leak at rear just behind to dist plug area. Damn I do hate that, appears the Silicone form-a-gasket let go. What are you guys using on the end of the intake? Joel Quote
joeld Posted January 14, 2008 Author Report Posted January 14, 2008 Sorry about that! 1995 Grand Prix, 3.1 Joel Quote
Crazy K Posted January 14, 2008 Report Posted January 14, 2008 you should only use FEL_PRO's PERMADRY gasket. no other. the cheaper gaskets have a short service life due to crappy design. if you can wait a bit... rockauto has the best deal on it. Quote
joeld Posted January 14, 2008 Author Report Posted January 14, 2008 I agree 100% with not using cheap gaskets, just not worth the risk. Last time I did use Fel-Pro, This is what I have used for many years. Only the end of the intake is leaking.And from what I've seen, this sealing area takes the silicone type of tube sealant. What is the preferred type here. Thanks Joel Quote
RYS Posted January 14, 2008 Report Posted January 14, 2008 I used Permatex Ultra Copper silicone. It's good to 700 degrees. Make sure you use alot on each ridge! I used a Fel-Pro kit when I did mine. I have no leaks and coolant is staying right where it should. Quote
joeld Posted January 14, 2008 Author Report Posted January 14, 2008 Thanks guys for the replies. Last time I used Permatex Black. First time this has ever failed me. Leaning towards trying the Great stuff. Joel Quote
Crazy K Posted January 14, 2008 Report Posted January 14, 2008 I should be clearer. I recommend AVOIDING even the basic fel-pro gasket, it too is inferior. if you pull your intake, you may discover this yourself. I've pulled the intake off of a bad 3400, and even though gaskets were relatively new and were FEL-PROs, they were already about the fail at the coolant ports. Quote
Chancho Posted January 15, 2008 Report Posted January 15, 2008 GM Intake gaskets all the way, they redesigned them and they even come with new bolts as the service manual says to use Quote
joeld Posted January 15, 2008 Author Report Posted January 15, 2008 Thank you. And I will look at the GM gaskets. That is what I usually use. A little more money sometimes, but you get what you pay for. And you were clear there CrazyK on the Permadry being better. Good info. Joel Quote
mfewtrail Posted January 15, 2008 Report Posted January 15, 2008 I use Permatex "The right stuff" gasket maker on the corners of lower intake manifolds. It sets up quickly and forms a rubber gasket. It's not too bad to clean up the next time you have to open up the engine either. The biggest mistake most people make on the corners of an intake manifold is using too little sealant. Lay a thick bead on there and you won't have any issues. Quote
SigEpCutlass Posted January 16, 2008 Report Posted January 16, 2008 You should use the Felpro Permadry gaskets or the revised GM gasket set. Don't use anything other than those unless you enjoy doing LIM jobs on a regular basis due to failures around the coolant passages. Quote
Brian P Posted January 16, 2008 Report Posted January 16, 2008 the perma-dry ones are the metal gaskets, with the molded rubber seals, right? Quote
Crazy K Posted January 16, 2008 Report Posted January 16, 2008 Von Kaiser said: the perma-dry ones are the metal gaskets, with the molded rubber seals, right? correct!! use nothing less. personnally, the 3.1 mpfi ones are paper and don;'t seem to have probelms.... why couldn't the 3x00 gaskets just be paper? Quote
Brian P Posted January 16, 2008 Report Posted January 16, 2008 Crazy K said: Von Kaiser said: the perma-dry ones are the metal gaskets, with the molded rubber seals, right? correct!! use nothing less. personnally, the 3.1 mpfi ones are paper and don;'t seem to have probelms.... why couldn't the 3x00 gaskets just be paper? All problems and failures aside, the 3100 LIM gaskets do a good job of shielding the intake manifolds from heat transfer thru the head and up. Whether or not that was the reason for that design I don't know. Quote
