My transmission is sometimes hard (really hard) to shift into gear, 1st, 2nd, reverse. I have lubed the shift cables and the shifter itself. And I also tried to lube the levers on top of the tranny. It only helps a little bit. Does anyone know that if the levers on top of the transmission can be replaced easly if they have excessive play (what would excessive play be?), or would something internal be binding up? Thanks for all your help.
96 GTP 5 speed
wouldnt worn/old synchronizers make it hard to get it gear. My dad's truck has a hard time going into first when coming to a stop sign
Robby
