cutlassdude96 Posted January 11, 2008 Report Share Posted January 11, 2008 lets see here LIM x2 rear struts water pump alt fuel pump/filter brakes both drivers and pass. door handles wont open from the outside I think thats it Quote Link to comment Share on other sites More sharing options...
ManicMechanic Posted January 11, 2008 Report Share Posted January 11, 2008 In one week... Freeze plug Water pump PS pump And still have a massive vacuum leak.. Ah, the joy of owning a 3.4 DOHC Why, oh why did I get rid of my little 3.1? All it needed in 2 years: 1 Alternator 1 ICM 1 ICM to CPS length of wiring 1 TSS I'm an idiot...lol Quote Link to comment Share on other sites More sharing options...
jeremy Posted January 14, 2008 Report Share Posted January 14, 2008 here's a breakdown of the issues with the w-bodies that I have owned: '89GP LE (3.1L) - Digital cluster malfuction, broken door handle, broken remote gas door cable (got rid of car with 142k) '92 Euro3.4 - n/a (traded in car w/<40k) '95 GTP - n/a (sold car w/<35k) '97 Cutlass Ser. IV 3100 - n/a (sold with 117k) '90 STE 3.1L 5spd - electrical problem with fuel pump cutting out, not specific to w-body though (~162k IIRC) '94 Cutlass 'vert 3100 - picked up with intake gasket failure, cracked monoleaf, two bad door handles among other things. (224k) '97 Monte Z34 - High pressure PS line cracked (sold with 176k, not leaking a drop of fluid) Quote Link to comment Share on other sites More sharing options...
89GP_SE Posted January 14, 2008 Report Share Posted January 14, 2008 My GP was pretty good to me Alternator CV joints Sep. Belt Ok is it just the 2 door gps that had this problem. Whenever I opened up the passenger door, you would hear click click, my 89 and my dads 88 both did that, and both on the pass side only. Quote Link to comment Share on other sites More sharing options...
Addicted To Boost Posted January 14, 2008 Report Share Posted January 14, 2008 Ok is it just the 2 door gps that had this problem. Whenever I opened up the passenger door, you would hear click click, my 89 and my dads 88 both did that, and both on the pass side only. Neither of my GPs do that. Quote Link to comment Share on other sites More sharing options...
1990lumina Posted January 14, 2008 Report Share Posted January 14, 2008 My GP was pretty good to me Alternator CV joints Sep. Belt Ok is it just the 2 door gps that had this problem. Whenever I opened up the passenger door, you would hear click click, my 89 and my dads 88 both did that, and both on the pass side only. Handle isn't adjusted right. My Lumina used to do that - I tightened up the linkage behind the handle and it's solid now. Quote Link to comment Share on other sites More sharing options...
brocno2454 Posted January 14, 2008 Report Share Posted January 14, 2008 My 89 Grand Prix: crankshaft postion sensor ICM coils alternator couple doorhandles my 90 Cutlass: icm and cps wiring door handle Quote Link to comment Share on other sites More sharing options...
89GP_SE Posted January 14, 2008 Report Share Posted January 14, 2008 My GP was pretty good to me Alternator CV joints Sep. Belt Ok is it just the 2 door gps that had this problem. Whenever I opened up the passenger door, you would hear click click, my 89 and my dads 88 both did that, and both on the pass side only. Handle isn't adjusted right. My Lumina used to do that - I tightened up the linkage behind the handle and it's solid now. no i think it had something to do with the little thingy that holds your door from opening too far. Quote Link to comment Share on other sites More sharing options...
Captain Ficho Posted January 16, 2008 Report Share Posted January 16, 2008 92 Cutlass Supreme Int'l, 105k miles. I've had it for about 5k miles myself, in that time I have had to replace: -Starter -Upper Radiator Hose Quote Link to comment Share on other sites More sharing options...
MonteCarloChick Posted January 16, 2008 Report Share Posted January 16, 2008 None. Just the typical rotting rust on the 5th gen Monte areas. Quote Link to comment Share on other sites More sharing options...
slick Posted January 16, 2008 Report Share Posted January 16, 2008 Major: Needed a new engine harness. Minor: Alternators Battery's LIM Brakes Suspension Quote Link to comment Share on other sites More sharing options...
npfd Posted January 16, 2008 Report Share Posted January 16, 2008 On our '97 cutlass with the 3100: - Door Handle - Fuel pump...should last the life of the car. - LIM gasket - Water Pump - Alternator - Front wheel bearing + CV joint - Water leaking in the trunk from rear window - Rear brakes rotors+pads - ball joints + tie rod ends - Both front strut bearing plates and a few more problems to go!!! Quote Link to comment Share on other sites More sharing options...
Euro Posted January 16, 2008 Report Share Posted January 16, 2008 Well...in the 10 months I've owned the GP, just over 10k miles and my warranty has already paid itself off So far it has been in for..... -New t-stat and coolant flush -New coils, plugs, and wires -New alternator -New front sway bar and 2 endlinks -New LIM gasket and upper intake plenum What we've done ourselves.. -Front and rear brakes -Battery Woot.. Quote Link to comment Share on other sites More sharing options...
