Oil Pressure-DOHC
I know I can fins it but if someone on here knows it please share. I think it 19 but I cant remember. Also what should it be at 3500rpm. The reson I ask is becasue with my gauge in my car I only read like 15 psi, but I think the gauge is not grounded right or something.
well the stock pressure gauge on mine reads max (80) cold and anytime im above like 3k and with the car at full temp idle it never reads below 1/4 (20). but that is the stock gauge so i dont know how accurate it is.
Oil pressure sending unit problems are a common problem on the V-8 engines; could easily be the same sending unit on those guys, too. I've had to replace the sending unit twice on my work truck. The gauge gradually reads lower and lower; you'd think the engine is wiped. Replacing the sending unit "adds" 30 psi of oil pressure.
Corroded wiring can have the same effect; I would not suspect a grounding issue at the sending unit--if the sending unit is screwed in properly, it won't lose it's ground.
GM dropped the oil gauge starting on '93 Luminas because the gauge fluctuated and people thought there was a problem. There was a service bulletin covering that issue. The oil gauge was replaced with a voltmeter which was probably a good thing--the alternator is more likely to give problems than the engine.
