roomylumy Posted January 4, 2008 Report Posted January 4, 2008 I assume this is the proper category for this. I don't imagine it is an easy job to do, but I was wondering if anyone had any tips to make it easier to change the gas tank on a 1990 Lumina. I have a leak near the top so I will probably run 1/2 tanks of fuel and do it in the warmer weather, but I'm trying to prepare in case it gets worse. Quote
jeremy Posted January 4, 2008 Report Posted January 4, 2008 The removal procedure is very straight forward and easy to do. There is a thread in the FAQ about fuel pump replacement that has the removal procedure for that tank Quote
Turbo231 Posted January 4, 2008 Report Posted January 4, 2008 Save you the work of finding it. http://members.aol.com/regal231/fuel.htm I sold the car about 3 years ago. Quote
Andrew Posted January 4, 2008 Report Posted January 4, 2008 http://www.w-body.com/forum/index.php?topic=64106.0 Quote
Addicted To Boost Posted January 5, 2008 Report Posted January 5, 2008 I replaced the gastank on my 89 Grand Prix SE a month ago and it was fairly easy. Just try to drain as much as fuel out of the tank or run it down as far as you can so you have an empty gastank to work with. The whole replacement is pretty straightforward. Also wear safety glasses- rust falling in your eyes is not pleasant! Quote
rockfangd Posted January 5, 2008 Report Posted January 5, 2008 Also wear safety glasses- rust falling in your eyes is not pleasant! agreed, been there done that, even with glasses it still finds its way around lol Quote
MikeP2389 Posted January 5, 2008 Report Posted January 5, 2008 Also wear safety glasses- rust falling in your eyes is not pleasant! agreed, been there done that, even with glasses it still finds its way around lol haha george and i had a pretty interesting time doin the tank on my monte. the only semi hard part is gettin the filler tubes back on and position the tank so you can bolt it back up. Quote
Addicted To Boost Posted January 6, 2008 Report Posted January 6, 2008 Oh yeah- my 18 year old filler tubes sucked to get back on... Quote
Q-Ball Posted January 6, 2008 Report Posted January 6, 2008 Anyone know where to get a new filler neck? My tanks been changed, but I'd really like to get a new filler neck. I was told they cant get them and I know of people just cutting where its bad and using a rubber hose. Quote
mfewtrail Posted January 6, 2008 Report Posted January 6, 2008 Oh yeah- my 18 year old filler tubes sucked to get back on... Mine was easy to put back on, but tough to remove due to the limited space in that area. Quote
Slade901 Posted January 6, 2008 Report Posted January 6, 2008 I have a crack on gas tank before. I dropped the gas tank. Emptied the gas. Filled my gas tank with water and emptied it. I did it 3 times. Filled the gas tank 1/2 with water. Used the gas combo welder you get from Walmart and soldered the crack. Fixed it. Quote
