RYS Posted December 31, 2007 Report Posted December 31, 2007 As the title says, my Cutlass has started to make a loud noise when it engages into gear from park or neutral. I was thinking tie rod ends but what else should I look at? Quote
1990lumina Posted December 31, 2007 Report Posted December 31, 2007 Transmision mount/lower engine mount. Mine are both fubared and I have a cracking sound when accelerating, and reverse to drive. Quote
RYS Posted December 31, 2007 Author Report Posted December 31, 2007 This is VERY loud kind of embarrassing. I'll have to take a look at that mount while someone puts it in gear. Quote
ns87 Posted December 31, 2007 Report Posted December 31, 2007 part of that sound was solved for me after the lower motor mount. I was going to replace the transmission mount but never had the patience to do that too Quote
19Cutlass94 Posted December 31, 2007 Report Posted December 31, 2007 yupp one of the mounts. Unless something else is very wrong but doubtful. Quote
Chancho Posted January 2, 2008 Report Posted January 2, 2008 id go with the lower engine mount, and that needs to be done asap because it can be bad if the mount goes out on you while your driving Quote
z34Phoenix Posted January 5, 2008 Report Posted January 5, 2008 i've had similar sounds and they are from the front brake pads sliding or moving slightly in the caliper Quote
RYS Posted January 6, 2008 Author Report Posted January 6, 2008 I looked under the hood and had someone put it in gear while holding the brake. The engine moves alot and it seems like the 2 top mounts that bolt to the rad support are shot. Quote
charged 3.1 Posted January 9, 2008 Report Posted January 9, 2008 Upper torque mounts are shot i would say. mine did the same thing when i bought the car. Quote
RYS Posted February 8, 2012 Author Report Posted February 8, 2012 I know this thread is ancient. But, the fluid filled transmission mount was busted and leaking. I replaced all of the engine/transmission mounts and everything was good as new. Quote
