NewCents05 Posted December 27, 2007 Report Posted December 27, 2007 hey does anyone know where i can find a cheap replacement clutch set for a 92 Lumina Z34 and how hard is it to replace myself? does anyone know the cost of replacing would run? my friend is mechanically inclined and said he could do it but it would take the whole day to do. Quote
White93z34 Posted December 27, 2007 Report Posted December 27, 2007 Presently I am running a "Perfection" clutch. Overall I am not pleased with it, it slips entirely too easy. However it does include a new TO bearing and pressure plate which is nice. Next clutch will probably be a more expensive performance one of some sort. It took me all of 30 minutes to install my clutch, however the engine and trans were out of the car when I did it. It is no small task to do clutch service on these cars, I don't know the exact procedure, but I believe it involves dropping the subframe out of the car and using a engine support to hold it all in there. defiantly a all day project. Quote
19Cutlass94 Posted December 27, 2007 Report Posted December 27, 2007 I think pulling the motor would be easier than dropping the subframe. Quote
TURBOLUMINA Posted December 27, 2007 Report Posted December 27, 2007 I ran an advance auto parts clutch and had good luck. I ran a whole summer on a 100 shot of juice before i went boosted, and had no problems. it ran about $180 if i remember correctly. And i have done several clutches in these cars, the easiest way is to take out driver side strut, and subframe bolts while rest of car is on jack stands. lower driver side of subframe down with jack, and trans will come out through the driver side. took me 2 hours start to finish. If you want further details, feel free to email me and i will walk you through it. jason-staples@hotmail.com Quote
skalor Posted December 30, 2007 Report Posted December 30, 2007 Presently I am running a "Perfection" clutch. Overall I am not pleased with it, it slips entirely too easy. However it does include a new TO bearing and pressure plate which is nice. Next clutch will probably be a more expensive performance one of some sort. It took me all of 30 minutes to install my clutch, however the engine and trans were out of the car when I did it. It is no small task to do clutch service on these cars, I don't know the exact procedure, but I believe it involves dropping the subframe out of the car and using a engine support to hold it all in there. defiantly a all day project. I ran the same clutch in my getrag 284 TGP. It wouldn't slip on the first WOT run, but if I did two back to back it would start to slip. It was my understanding that the stock 284 clutch was rated at 300 ft lbs of torque, which was probably about what my TGP was making. Quote
radman3120 Posted January 8, 2008 Report Posted January 8, 2008 Presently I am running a "Perfection" clutch. Overall I am not pleased with it, it slips entirely too easy. However it does include a new TO bearing and pressure plate which is nice. Next clutch will probably be a more expensive performance one of some sort. It took me all of 30 minutes to install my clutch, however the engine and trans were out of the car when I did it. It is no small task to do clutch service on these cars, I don't know the exact procedure, but I believe it involves dropping the subframe out of the car and using a engine support to hold it all in there. defiantly a all day project. I ran the same clutch in my getrag 284 TGP. It wouldn't slip on the first WOT run, but if I did two back to back it would start to slip. It was my understanding that the stock 284 clutch was rated at 300 ft lbs of torque, which was probably about what my TGP was making. this clutch from advance auto is by far the cheapest ive been able to find. its what i used when i first got my car a few years ago but its already slipping, too. i also installed it with the engine already out so i couldnt tell you about the labor. let me know how you end up doing it since i will be doing it in the spring. Quote
