CutSupreme93 Posted December 26, 2007 Report Posted December 26, 2007 i jus did the alternator on my 3.4 DOHC in the garage and after i put the car back together the brake light came on when i started it. and ideas? Quote
CutSupreme93 Posted December 26, 2007 Author Report Posted December 26, 2007 Parking brake on? nope. if a caliper is locked or the brakes need to be changed could that make the light turn on? Quote
ManicMechanic Posted December 26, 2007 Report Posted December 26, 2007 Not usually. It's generally tripped by low fluid level. Check that next. Have you had the parking brake on? Sometimes the switch sticks or the pedal doesn't always come back up all the way. Quote
CutSupreme93 Posted December 26, 2007 Author Report Posted December 26, 2007 i never have used the parking brake and the fluid level is fine. Quote
ManicMechanic Posted December 26, 2007 Report Posted December 26, 2007 Something got unplugged...Unless your pads are really worn down... Quote
CutSupreme93 Posted December 26, 2007 Author Report Posted December 26, 2007 so if the pads need to be replaced then the light will come on? Quote
ManicMechanic Posted December 26, 2007 Report Posted December 26, 2007 At times, but usually it's because the fluid level is low. Quote
CutSupreme93 Posted December 26, 2007 Author Report Posted December 26, 2007 i just opened the cap to check and it was almost full. Quote
Schurkey Posted December 26, 2007 Report Posted December 26, 2007 i never have used the parking brake and the fluid level is fine. The rear brakes only adjust when you activate the park brake. Failure to use the park brake now and then means the rear calipers don't adjust properly. Are you saying the brake lights on the rear of the car came on; or the warning light for the brakes on the dashboard is lit? Quote
CutSupreme93 Posted December 27, 2007 Author Report Posted December 27, 2007 i never have used the parking brake and the fluid level is fine. The rear brakes only adjust when you activate the park brake. Failure to use the park brake now and then means the rear calipers don't adjust properly. Are you saying the brake lights on the rear of the car came on; or the warning light for the brakes on the dashboard is lit? yea i used it when i changed the rear brakes but havent since then. the warning light on the dashboard is lit. Quote
