CutSupreme93 Posted December 23, 2007 Report Posted December 23, 2007 i just replaced the alternator and when i did so i removed the belt tensioner by accident to remove the belt. i put everything back together but there is a squeaking coming from somehwere around the tensioner and the belt did not tighten up. did i put the belt tensioner on wrong or is it just shot or do i have another problem? Quote
jeremy Posted December 23, 2007 Report Posted December 23, 2007 it could either be installed wrong or shot.......how loose it the belt? Quote
CutSupreme93 Posted December 23, 2007 Author Report Posted December 23, 2007 how are u suppost to install it or is there not any specific way? Quote
jeremy Posted December 23, 2007 Report Posted December 23, 2007 how are u suppost to install it or is there not any specific way? well if you tightened it down and it isn't in the location that it should be that would be a problem....if it looks like it is in the right location then it could be bad.....I have always just replaced the tensioner when I replaced the belt out of habit. Quote
Chancho Posted December 23, 2007 Report Posted December 23, 2007 you need to verify that you installed the tensioner on right, and if infact you did then verify a strong tension on the belt if there isnt one then replace the tensioner, if there is then you might need a new belt Quote
CutSupreme93 Posted December 23, 2007 Author Report Posted December 23, 2007 ok, thanks i appreciate the help Quote
joey b Posted December 24, 2007 Report Posted December 24, 2007 I think you have to some how load a force on the spring. I really don't remember. I do think that there are little teeth that I had to latch into the block and then rotate the tensioner and press the tensioner the rest of the way in. At its resting position is there a spring force on the tensioner? There should be. Quote
CutSupreme93 Posted December 25, 2007 Author Report Posted December 25, 2007 i put a new tensioner on and the car all back together but now its idling really low. Quote
CutSupreme93 Posted December 25, 2007 Author Report Posted December 25, 2007 Do an idle relearn? dont know what that is or how to do it? Quote
ManicMechanic Posted December 25, 2007 Report Posted December 25, 2007 http://www.w-body.com/forum/index.php?topic=31176.0 Quote
CutSupreme93 Posted December 26, 2007 Author Report Posted December 26, 2007 did the idle relearn fix it? no its still idling low and the brake light is on. my car always seems to brake when winter comes Quote
