Are there any suppliers that make Poly Bushings for my 96GTP?
I would be looking for the control arm, inner/outer front and rear sway bar and engine mounts.
If you go to after market lateral links and trailing arms you can get poly bushings with them. I was unable to find any for the control arms, so I just got OE parts to replace the old ones.
If you switch to poly, make sure you get greasable bushings, and use a synthetic grease, preferably one with silicone in it. Something else you might be able to find is silicone impregnated poly.
For sway bar bushings check out the link Jason gave to my suspension work, there are ES part numbers in there.
Jamie
