Aftermarket Radio Install in 1988 Grand Prix
I realize I could swap out the IP carrier but I want my interior to match, plus my interior is nicer than anything I can get out of the junk yard.
I found this install kit made by metra for 88-89 pontiac grand prixs.
http://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=265-667&ctab=15#Tabs
Does anyone have any experience with this install kit? Any pictures of how it looks/works? This is the only one I can find for this car. Any help will be greatly appreciated.
The install kit's for GM's 88-93ish are pretty much all the standard snap fit, and bolt into the factory location.
However, I use the Metra kit at work, and it works fine.
Have you ever done an 88 or 89 gp? They have the modular radio where it is not all that deep behind the radio part. I just want to make sure this is going to work ok before I buy it. Any pictures would be great
Yeah, I couldn't count on my fingers and toe's how many i've done, this fall alone.
Just break out the plastic behind the radio, and you will have as much depth as you want.
It's just the standard GM harness, so yes that is the one. Be sure to get an antenna adapter also, GM's use the Mini style.
As far as cutting out is concerned, your fist, air saw, hacksaw, dremmel, tin snips, etc..... I've used them all, be creative. More commonly, though, I just grab and twist, it eventually breaks off.
The scosche or metra kit will work. They will be the same set-up: Take front shroud, attach to GM pocket. Attach brackets to pocket, insert cage into kit, and bolt into the dash.
