134a Retro Question
Looking for the LOW side connector on the TGP to change it over to 134a refrigerant - already found high connector.
Anyone already do this changeover....with success?
Thanx - Dave :cheers:
Already bought kit from auto supply store - high / low connector adapters.
Just need to locate low pressure connector.
Guest fatguy
To correctly do the conversion, you need to replace the accumulator and all of the o-rings. There are two for each: evaporator coil, compressor, condensor coil and accumulator. The two ports are vertically side by side. You found the high side so look below it and the low side is just below it horizontally. Have fun hooking up the hose to the fitting :shock:
Thank you. I knew I could count on decent help here.
Take care - Dave :cheers:
