Fmr12B Posted December 10, 2007 Report Posted December 10, 2007 Ordering up all new KYB's from TireRack to replace the worn suspension and noted alongside the struts they also sell strut mounts. Do I need to buy new mounts? Just front? Just rear? If so, do I need the heavy duty front strut mounts? If not until I break something, is there any foolproof way in telling if I need new mounts before breaking down the suspension? In its 113K mile life I seriously doubt it has ever seen snow or salt so there no rusted parts or bolts from what I can tell. Thanks! Quote
Crazy K Posted December 10, 2007 Report Posted December 10, 2007 being a CA car? not likely. THe ones that usually go bad are the ones in the rear. I've been experimenting with servicing the OEM fronts with some trial and error by increasing fluid viscocity. Quote
Andrew Posted December 10, 2007 Report Posted December 10, 2007 If not until I break something, is there any foolproof way in telling if I need new mounts before breaking down the suspension? In its 113K mile life I seriously doubt it has ever seen snow or salt so there no rusted parts or bolts from what I can tell. a bad strut mount is usually associated with a clunk type noise. if you dont have that noise, then yours are likely fine. however, it is a 12 year old car with over 100k miles, so in my opinion they are due if they havent been replaced once already. Quote
mfewtrail Posted December 10, 2007 Report Posted December 10, 2007 The front mounts are almost never bad. The rear wear out a lot quicker than the fronts. I'd say about ~140-150K is the average lifespan for the rear mounts. Quote
Chancho Posted December 10, 2007 Report Posted December 10, 2007 I would replace the rear mounts, only because the rear suspension has to be dropped therefore it needs an allignment, however the front mount can be done any day you chose if it happens to go bad Quote
SigEpCutlass Posted December 10, 2007 Report Posted December 10, 2007 Never under any circumstances leave the mounts on when replacing the struts. I did that the last time to make things easier, and I've had to replace 2 out of the 4 mounts before I redo the suspension over the winter. Quote
Fmr12B Posted December 10, 2007 Author Report Posted December 10, 2007 I'll be placing an order for two rear strut mounts along with the 4 new struts. If the front's are worn I'll pick those up from my local Advance Auto or do those at a later time. If I decide to buy front mounts do I need the heavy duty ones? Quote
Andrew Posted December 10, 2007 Report Posted December 10, 2007 the heavy duty ones are for a heavy duty suspension package, i forget what its called. i doubt you would need them. Quote
1990lumina Posted December 10, 2007 Report Posted December 10, 2007 I reused the original rear mounts on my Lumina two years ago..everything is still holding together. Now that I say that one will probably pop through tomororw lol Quote
Fmr12B Posted December 10, 2007 Author Report Posted December 10, 2007 Well the TireRack is now $480 wealthier! KYB Front $39x2 KYB Rear $50x2 KYB Rear Mount $40x2 General Altimax RT 225/60/16 $68x2 for the Concorde LXi + Shipping of $86 Quote
Crazy K Posted December 11, 2007 Report Posted December 11, 2007 Well the TireRack is now $480 wealthier! KYB Front $39x2 KYB Rear $50x2 KYB Rear Mount $40x2 General Altimax RT 225/60/16 $68x2 for the Concorde LXi + Shipping of $86 you shoulda checked out rockauto!!!!!!!! Quote
Fmr12B Posted December 11, 2007 Author Report Posted December 11, 2007 you shoulda checked out rockauto!!!!!!!! I did: Only thing cheaper was the reat strut mount by $1.21 KYB Front = $50 KYB Rear = $55 Perhaps shipping was cheaper? Quote
Crazy K Posted December 11, 2007 Report Posted December 11, 2007 oh.. you included a tire??? that makes the difference. yeah rockauto shipping may have been cheaper... but maybe not to Ca. Quote
Chancho Posted December 11, 2007 Report Posted December 11, 2007 Yea kyb's arnt too cheap. But as i said you should be fine, and if the front mounts need to be replaced they are pie, even after you do the struts. Quote
AWeb80 Posted December 11, 2007 Report Posted December 11, 2007 KYB's Are Priced Right Along With Manho struts. and for what you get, KYB's Are Awesome For The Price. Quote
toms92gpse Posted December 15, 2007 Report Posted December 15, 2007 Kybgr2s FTMFW. I put mine one about 50-60k ago and they are still performing top notch. I put new mounts all the way around. If you front ones look like the rubber is starting to dryrot then I would replace them. If not I would just keep them. Quote
