synistershadows Posted December 7, 2007 Report Posted December 7, 2007 so i think my tranny finnaly went i was leaving work today and i got up the slight hill and had stopped to turn onto the main strech, i let off the brake and the car started to roll backwards like it was in neutral so i shifted from overdrive to drive and the same thing i did this through all the forward gears. finally in 1st the car would move forward very slowly and not untill i reached 4200 rpm so i took it back to work shut it down started again only now its smoking from the exhaust side of the car i open the hood and smell burning and white smoke. i parked it in the shop at work untill i can get one of the mechanincs to take a look at it tomorrow but would you guys sa that my tranny has finally gone? Quote
1990lumina Posted December 7, 2007 Report Posted December 7, 2007 Check the tranny if there is fluid in it. I noticed your other thread says you're leaking red fluid. I bet that tranny hose finally blew on you and you pumped all the fluid onto the ground. Quote
synistershadows Posted December 7, 2007 Author Report Posted December 7, 2007 but it should have still run though right even with no fluid just really badly :S Quote
GP1138 Posted December 7, 2007 Report Posted December 7, 2007 but it should have still run though right even with no fluid just really badly :S Uh.. a transmission is hydraulic by nature, so that's a big NO right there. I'll bet I was right in your other thread... transmission line blew. Quote
1990lumina Posted December 7, 2007 Report Posted December 7, 2007 No, it will not run properly/if at all with no fluid in it. An automatic transmission requires the proper amount of fluid to be in the hydraylic circuits and torque converter at all times. Start there. Check your fluid. Quote
ns87 Posted December 7, 2007 Report Posted December 7, 2007 Someone posted on here a while ago that they knew someone who had a beater lumina: It had a trans leak. And when it wouldn't drive in gear, he filled it up with fluid and it was fine. Deff check the level tomorrow, it could just need more fluid. some of these transmissions are kinda bullet proof, others are weaaaaaak. Kinda a crap shoot Quote
1990lumina Posted December 7, 2007 Report Posted December 7, 2007 Someone posted on here a while ago that they knew someone who had a beater lumina: It had a trans leak. And when it wouldn't drive in gear, he filled it up with fluid and it was fine. Deff check the level tomorrow, it could just need more fluid. some of these transmissions are kinda bullet proof, others are weaaaaaak. Kinda a crap shoot That was proably my friend at work lol...still drives that car too..though he got the leak fixed finally lol (pan gasket). Yeah he would lose reverse first..then he dumped a liter or so of fluid in and kept driivng haha Quote
synistershadows Posted December 7, 2007 Author Report Posted December 7, 2007 ill def check that out tomorrow and if it is that line how hard a fix is it and what might be the aprox cost? Quote
ns87 Posted December 7, 2007 Report Posted December 7, 2007 Someone posted on here a while ago that they knew someone who had a beater lumina: It had a trans leak. And when it wouldn't drive in gear, he filled it up with fluid and it was fine. Deff check the level tomorrow, it could just need more fluid. some of these transmissions are kinda bullet proof, others are weaaaaaak. Kinda a crap shoot That was proably my friend at work lol...still drives that car too..though he got the leak fixed finally lol (pan gasket). Yeah he would lose reverse first..then he dumped a liter or so of fluid in and kept driivng haha There ya go! I guess it was you telling the story Quote
ismellrealbad Posted December 7, 2007 Report Posted December 7, 2007 ill def check that out tomorrow and if it is that line how hard a fix is it and what might be the aprox cost? I think i got a set for $35 from the dealer. Find the 2 metal lines coming off the side of the rad and follow them to ur trans. You can decided form there ive never touched them on a dohc. Quote
synistershadows Posted December 7, 2007 Author Report Posted December 7, 2007 2 lines kinda like say the width of the A/C lines comming off the lower driver side of the rad with what looks like bolts holding them on if i remember correctly last time i had the car up? Quote
Chancho Posted December 7, 2007 Report Posted December 7, 2007 yea you can only hope that the tranny is salvagable however, my experience with these trannys is no fluid, no tranny untill it gets a rebuild, no fun Quote
synistershadows Posted December 8, 2007 Author Report Posted December 8, 2007 well its fixed turned you it needed 2 liters of tranyn fluid and a new hose clamp Quote
mediabandit Posted December 8, 2007 Report Posted December 8, 2007 well its fixed turned you it needed 2 liters of tranyn fluid and a new hose clamp cool, always nice when it turns out to be an easy fix. Quote
Regal_GS_1989 Posted December 8, 2007 Report Posted December 8, 2007 The Tranny line blew on my cutlass about a week ago, while my GF was driving it. I was so proud of her, she knew exactly what to do when the car started acting wierd. She shut it off, called me and explained what happened, i had her look and sure enough there was a nice big puddle under the car. Had it towed for free, and it cost me 45$ to have the line fixed, and about 8 liters of fluid. Quote
synistershadows Posted December 8, 2007 Author Report Posted December 8, 2007 and i figured out why it was smokeing and smelling burnt the line came loose and when pressurized it was spraying tranny fluid up onto my exhaust Quote
