synistershadows Posted December 4, 2007 Report Posted December 4, 2007 ok so i dunno what it is but theres a leak comming from up front of my cutty kinda by the radiator but its a redish fluid I thought it might be tranny fluid but i keep checking that regularly and it hasnt changed levels what could this leak be?? as well after driving for a while and stopping i see white smoke comming from under my hood i opened it up to take a look at where its commming from and i cant really see where its on the driver side kinda by the air box and it smells kinda sweet like anitfreeze i just put in a new t-stat and it looks like the gasket has corroded on the bottom half only and looks like it could have been leaking at one point but its not leaking anymore from what i can tell please help me figure out what these problems could be as i would like to keep this engine running well and possibly someday boost it. Quote
Chancho Posted December 4, 2007 Report Posted December 4, 2007 are you running dex-cool, because its prob coolant, tranny fluid has a distinct smell Quote
synistershadows Posted December 4, 2007 Author Report Posted December 4, 2007 no im runnign the green stuff and its acctully 2 leaks one being the one up front underneith the other being the sweet smell one Quote
Chancho Posted December 4, 2007 Report Posted December 4, 2007 sweet smell is almost always coolant, and maybie its burnign off somewhere thats y u get the sweet smell, and the redish is tranny fluid, either a bad pan gasket, or these cars have a tendancy that when the tranny is overfilled and the car is driven somewhat harder then normal (tranny gets hotter then normal) they will leak Quote
synistershadows Posted December 4, 2007 Author Report Posted December 4, 2007 its comming from up front though up by the radiator Quote
dohc v6 Posted December 4, 2007 Report Posted December 4, 2007 The fact that u said that it smokes tells me that the coolant is hitting the exhaust. since the exhasut is only on the drivers side u need to look over there. If you just did a thermostat then you need to take the air box off and keep loking. I know when I do my plenum, the throttle body bypass hose always leaks and I have to tighten it. Look around, the leaks there, but deffinitly look around about the exhasut. Quote
rockfangd Posted December 5, 2007 Report Posted December 5, 2007 if it is leaking red i would be willing to almost place money on rotted tranny cooler lines. they are under the airbox at the radiator and love to spray under there. Quote
synistershadows Posted December 5, 2007 Author Report Posted December 5, 2007 are thoes lines hard to fix? Quote
dohc v6 Posted December 5, 2007 Report Posted December 5, 2007 What? tranny lines? The tranny lines go under everything. I doubt that its the tranny lines. You need to find out exactl what is leaking weather its tranny fluid or coolant. We need to know to futher diagnoisis Quote
synistershadows Posted December 5, 2007 Author Report Posted December 5, 2007 well theres 2 leaks like i said one being the sweet smelling one the other the red fluid up front Quote
oceancon Posted December 6, 2007 Report Posted December 6, 2007 ps fluid is also red - so check those lines esp. where they meet the pump.. Quote
dohc v6 Posted December 6, 2007 Report Posted December 6, 2007 Umm, no. Power steering fluid is clear, people put tranny fluid in there. That should be flushed out asap. Quote
BXX Posted December 6, 2007 Report Posted December 6, 2007 Umm, no. Power steering fluid is clear, people put tranny fluid in there. That should be flushed out asap. a lot of powersteering fluid is red, especially the kinds with stopleak.. If the powersteering fluid is old, as in never been drained out, it can look very red as well.. tranny fluid can also be substituted as PS fluid in emergencies, and it will also act as a stop leak because it will cause the seals to swell a tab bit. Sometime it can cause damage, other times it can stay in there and not damage anything... Quote
1990lumina Posted December 6, 2007 Report Posted December 6, 2007 If you can't find the leak there are dyes you can buy that will help you find the source of the leak. Quote
GP1138 Posted December 7, 2007 Report Posted December 7, 2007 It most certainly COULD be transmission fluid, the transmission cooler lines go into the radiator on the right side. My lower fitting on my new car was leaking there. Quote
synistershadows Posted December 7, 2007 Author Report Posted December 7, 2007 i think that might be it are they hard/expensive to fix? Quote
