Throttle body size
Can someone please tell me the stock throttle body size for an 88 grand prix 2.8 litre, and also the throttle body size for the later 3.1 version? If the 3.1 is even slightly larger I think I'll replace my 2.8's throttle body.
Later
Jay
I don't think there is a difference between the 3.1 and 2.8 throttle bodies. Someone correct me if I'm wrong though.
the 3.1L and the 2.8L are the same motor, only difference is the 3.1L is a stroked 2.8. So, their TB size is 52mm in diameter. There are performance ones made that are 62mm at http://www.fdpperformance.com However, if this is going to be your first mod, you are going to see much from it. And, you would need to port-match your plenum to meet the TB right. A bigger TB is something you would need after some porting and polishing has been done to the heads and intakes, free-flowing exhaust, some kinda intake, some internals and forced induction would be well complemented by this mod.
Robby
