GPdriver1986 Posted July 13, 2003 Report Share Posted July 13, 2003 I'm not sure but I think I found the tach wire, I know its supposed to be white and by the DIS, but I see two white wires. I found the two white wires in the wire loom that run right by the DIS. Does anyone have a picture of the wire? After I find the tach wire where do I have to connect it (on the cluster)? Quote Link to comment Share on other sites More sharing options...
god910 Posted July 13, 2003 Report Share Posted July 13, 2003 We always used the ground to a coil. Can't tell you what it is though. Whatch out, big helper here. Quote Link to comment Share on other sites More sharing options...
Robby1870 Posted July 13, 2003 Report Share Posted July 13, 2003 Well, you are right it is a white wire, but when I hooked mine up, I had to guess at which one was it, and I guess right the first time. Also, the orange wire that comes from the ALDL connector is a tach wire too, if you want to splice into that Robby Quote Link to comment Share on other sites More sharing options...
Whiskey River Posted July 14, 2003 Report Share Posted July 14, 2003 As I'm not real familiar with the GP's, you'll have to excuse me. If you are installing an aftermarket tach, then I'm not real sure where you would tap into. The DIS has two white wires, as you have already found out. On the cars with analog tachs installed, the white wire next to the purple wire is the tach wire. The other white wire is a tach signal for the ECM. Hope this helps determine which white wire you need to splice into. Quote Link to comment Share on other sites More sharing options...
GnatGoSplat Posted July 14, 2003 Report Share Posted July 14, 2003 The orange ALDL wire ONLY supplies a tach signal to digital clusters manufactured by Nippon Denso. I think this is ONLY the Cutlass and Regal digital gauges clusters. All other clusters need the white tach wire, including Grand Prix half analog/digital clusters because they are made by Delco. Quote Link to comment Share on other sites More sharing options...
GPdriver1986 Posted July 14, 2003 Author Report Share Posted July 14, 2003 As I'm not real familiar with the GP's, you'll have to excuse me. If you are installing an aftermarket tach, then I'm not real sure where you would tap into. The DIS has two white wires, as you have already found out. On the cars with analog tachs installed, the white wire next to the purple wire is the tach wire. The other white wire is a tach signal for the ECM. Hope this helps determine which white wire you need to splice into._________________ So which white wire do I tap into? Quote Link to comment Share on other sites More sharing options...
Whiskey River Posted July 14, 2003 Report Share Posted July 14, 2003 It will be the white wire closest to the purple wire. Quote Link to comment Share on other sites More sharing options...
GPdriver1986 Posted July 14, 2003 Author Report Share Posted July 14, 2003 So then I have to somehow bring it inside the car? Quote Link to comment Share on other sites More sharing options...
Whiskey River Posted July 14, 2003 Report Share Posted July 14, 2003 When I ran mine for my tach, I ran it through the wire loom around to the right of the motor then through the grommet above the steering column. That allowed me to run it up through my dash and into the connector for my tach. Quote Link to comment Share on other sites More sharing options...
