gpchris Posted November 29, 2007 Report Posted November 29, 2007 These are directly from ther GM service manual. Accelerator Control Cable Bracket Bolt – 18lb.ft. A/C Compressor to Front Cover Bolt – 37lb.ft. AIR Pipe – 15lb.ft. Brace Bracket to Rear Engine Mounting Bracket Nut – 35lb.ft Camshaft Carrier Bolt – 20lb.ft. Camshaft Cover Bolt – 97lb.in. Camshaft Carrier Thrust Plate Bolt – 89lb.in. Camshaft Carrier Thrust Plate Cover Bolt – 89lb.in. Camshaft Drive Belt Cover Bolt – 89lb.in. Camshaft Drive Sprocket Bolt – 81lb.ft. Camshaft Timing Belt Idler Pulley Bolt Torque Angle Method – 11lb.ft. + 37* Hand Method 37lb.ft. Camshaft Timing Belt Tensioner Bracket Bolt – 37lb.ft. Camshaft timing Belt Tensioner Pulley Pivot Bolt – Torque Angle Method – 11lb.ft. + 40* Hand Method – 37lb.ft. Camshaft Timing Belt Tensioner Side Plate Bold – 18lb.ft. Clutch Pressure Plate Retaining Bolt – 18lb.ft. Connecting Rod Cap Nut – 37lb.ft. Coolant Bypass Nut – 18lb.ft. Coolant Inlet Housing Bolt – 20lb.ft. Coolant Outlet Bolt – 97lb.in. Coolant Pump Bolt – 97lb.in. Coolant Temperature Sensor – 13lb.ft. Crankshaft Balancer Mounting Bolt – 79lb.ft. Crankshaft Main Bearing Cap Bolt- 37lb.ft. + 75* Crankshaft Main Bearing Cap Stud – 37lb.ft. + 77* Crankshaft Oil Deflector Nut – 18lb.ft. Crankshaft Pulley to Crankshaft Damper Bolt – 37lb.in. Crankshaft Position Sensor Bolt 71lb.in. Cylinder Head Bolt (Special Sequence) – 37lb.ft. + 90* EGR Tube Assembly Bolt – 18lb.ft. EGR Valve Assembly Bolt – 18lb.ft. Electronic Ignition Module Assembly Bolt/Stud – 18lb.ft. Electronic Ignition Module Assembly Nut – 18lb.ft Engine Block Coolant Drain Plug – 14lb.ft. Engine Block Oil Gallery Plug – Center Rear – 24lb.ft. Engine Block Oil Gallery Plug – To Oil Filter – 24lb.ft. Engine Mount to Bracket Nut – 35lb.ft. Engine Mounting Bracket to Engine Bolt – 43lb.ft. Engine Mounting Bracket to Transaxle Bolt – 43lb.ft. Engine Oil Level Sensor Stud – 89lb.in Engine Oil Manifold Bolt – 20lb.ft. Exhaust Crossover Nut – 18lb.ft. Exhaust Crossover Stud – 80lb.in. Exhaust Manifold Heat Shield Nut – 116lb.in. Exhaust Manifold Nut – 116lb.in. Exhaust Manifold Stud – 13lb.ft. Flywheel to Crankshaft Bolt – 60lb.ft. Front Cover Bolts (Large) – 35lb.ft. Front Cover Bolts (Small) – 20lb.ft. Front Cover to Engine Lift Hood Bolt – 18lb.ft. Front Engine Lift Good to Right Camshaft Carrier Bolt – 37lb.ft. Front Engine Lift Hook to Right Cylinder Head Bolt (Access Through Front Cover) – 37lb.ft. Front Engine Mounting Bracket to Engine Bolt – 63lb.ft. Fuel Injector Sight Shield Nut – 89lb.in. Fuel Pipe Slip Bolt – 62lb.in. Fuel Pipe Retainer Screw - 62lb.in. Fuel Rail Assembly Bolt – 89lb.in Ignition Coil Bolt/Screw – 18lb.ft. Ignition Coil Nut – 18lb.ft. Intermediate Shaft Belt Sprocket Bolt – 96lb.ft. Intermediate Drive Shaft Retainer Screw – 89lb.in. Knock Sensor – 15lb.ft. Lower Intake Manifold Mounting Bolt – 20lb.ft. Oil Cooler Connector – 30lb.ft. Oil Cooler Hose Fitting – 18lb.ft. Oil Distribution Cover Bolt – 20lb.ft Oil Filter – 12lb.ft. Oil Filter Fitting – 49lb.ft Oil Level Indicator Bolt – 89lb.in. Oil Pan Baffle But – 18ft.lb. Oil Pan Bolt – Except Rear – 97lb.in Oil Pan Bolt – Rear – 18lb.ft Oil Pan Nut – 97lb.in Oil Pan Stud to Cylinder Block – 89lb.in. Oil Pressure Switch – 24lb.ft. Oil Pump Cover Bolt – 89lb.in. Oil Pump drive Clamp Bolt – 27lb.ft Oil Pump to Rear Main Cap Bolt – 40lb.ft. Power Brake Booster Vacuum Pipe Fitting – 13lb.ft. Power Steering Pump to Bracket Bolt – 25lb.ft. Rear Intermediate Shaft Cover Bolt – 89lb.in. Rear Engine Mount Strut Bracket Bolt – 60lb.ft. Rear Engine Mounting Brace to Engine Bolt – 76lb.ft. Serpentine Drive Belt Tensioner Bolt – 40lb.ft. Spark Plug New Cylinder Head – First Time Installation – 18lb.ft. Non First Time Installation – 11lb.ft. Spark Plug Wire Support Bolt – 89lb.in Throttle Body Heater Outlet Nose Nipp13lb.ftle - Timing Belt Cover Bolt – 89lb.in Timing Chain Tensioner Bolt – 18lb.ft Torque Strut and Engine Lift Bracket Bolt – 52lb.ft. Upper Intake Manifold Mount Bolt – 97lb.in. Upper Intake Manifold Retaining Bolt – 20lb.ft. Upper Intake Manifold Retaining Nut - 20lb.ft. Water Inlet Fitting to Front Cover – 13lb.ft. Quote
Q-Ball Posted November 29, 2007 Report Posted November 29, 2007 Sticky this! I should scan my service manauls. Quote
gpchris Posted November 29, 2007 Author Report Posted November 29, 2007 If this thread get sticky'd dont lock it! I can add torque specs for all the 60*s Quote
