RYS Posted November 27, 2007 Report Posted November 27, 2007 The brake light is lit on my dash. 1991 cut supreme 3.1. The car was sitting for 4 days and the booster pipe that goes to the back of th eplenum isnt 100% tight could either of these be the reason? Light was not on before I disconnected the pipe or before sitting. Quote
JakeMetz63 Posted November 27, 2007 Report Posted November 27, 2007 Heh, I just have to ask, but is the e-brake stuck on at all? Quote
Bake82 Posted November 27, 2007 Report Posted November 27, 2007 try and get that pipe on tight. Also did you un hook a sensor at all for the brakes? Quote
RYS Posted November 27, 2007 Author Report Posted November 27, 2007 I did have the ebrake on but I pulled the lever several times it seems to be released?? Quote
Psych0matt Posted November 27, 2007 Report Posted November 27, 2007 put the ebrake back on, and then release it again. If there isnt very much tension on it it wont pop back up, but it might be one click down or something to cause the light to be on Quote
ns87 Posted November 27, 2007 Report Posted November 27, 2007 put the ebrake back on, and then release it again. If there isnt very much tension on it it wont pop back up, but it might be one click down or something to cause the light to be on X2! I haven't had an ebrake in my car for several years , but I remember more than once the pedal being clicked down one and light being on. Physically lift the e brake pedal while holding the release bar Quote
RYS Posted November 27, 2007 Author Report Posted November 27, 2007 put the ebrake back on, and then release it again. If there isnt very much tension on it it wont pop back up, but it might be one click down or something to cause the light to be on Thank you the light is out. Quote
Psych0matt Posted November 27, 2007 Report Posted November 27, 2007 [me=Psych0matt]actually helped with something![/me] Quote
