Chancho Posted November 30, 2007 Author Report Share Posted November 30, 2007 that shows how to disable both DRL's and the Automatic Lights, i guess there really isnt a way to disable just the DRL's while leaving automatic lights working Quote Link to comment Share on other sites More sharing options...
runt Posted November 30, 2007 Report Share Posted November 30, 2007 I can't speak for the Lumina's but on the GP's on the left side of the dash behind a small panel there is a heat sink. There is a plug going into said heat sink. If you unplug that it will disable the DRL's and retain the Autolights (which is how my car is). Possibly look for something similar? Quote Link to comment Share on other sites More sharing options...
Nick1234 Posted November 30, 2007 Report Share Posted November 30, 2007 I can't speak for the Lumina's but on the GP's on the left side of the dash behind a small panel there is a heat sink. There is a plug going into said heat sink. If you unplug that it will disable the DRL's and retain the Autolights (which is how my car is). Possibly look for something similar? ill have to check into that. Quote Link to comment Share on other sites More sharing options...
slick Posted November 30, 2007 Report Share Posted November 30, 2007 The Impala's aren't quite as easy, atleast coming from a parking lamp/headlamp point. The headlamps and parking lamps are wired much differently than the other 2nd gens. For example, when doing a remote start/keyless/alarm, or whatever, it requires you to isolate the parking lights away from the switch. The use of a diode and a relay is necessary. But... not sure if this applies to the DRL's though. Quote Link to comment Share on other sites More sharing options...
Euro Posted November 30, 2007 Report Share Posted November 30, 2007 I can't speak for the Lumina's but on the GP's on the left side of the dash behind a small panel there is a heat sink. There is a plug going into said heat sink. If you unplug that it will disable the DRL's and retain the Autolights (which is how my car is). Possibly look for something similar? Thank you. I couldn't find the words to say that and have it make sense. And QOCGP had a write up with pictures, but they took that down, I can't find it. Quote Link to comment Share on other sites More sharing options...
Chancho Posted November 30, 2007 Author Report Share Posted November 30, 2007 Ill have to check that out on my car, ill let you all know Quote Link to comment Share on other sites More sharing options...
