joey b Posted November 22, 2007 Report Posted November 22, 2007 cutlass convert. I don't know what the problem is. I doesn't like to latch and at random will come unlatched. Seems like the latching mechanism is a little loose as well. Can I rebuild this mechanism or maybe just replace it without changing the actual key? Quote
Bake82 Posted November 22, 2007 Report Posted November 22, 2007 Hey, I had this happen to me. You can unbolt the latching mechanism and get a new one, without having to change the key. The latching mechanism is held on by 4-6 bolts and is replacable. All you need to do is make sure you align it with the rod that is connected to the key hole, and you're set! Quote
AWeb80 Posted November 22, 2007 Report Posted November 22, 2007 Never Heard Of This Happening Before Quote
Crazy K Posted November 22, 2007 Report Posted November 22, 2007 easy to replace. there are two bolts that mount the latch to the lid, and two more *if* you have have a power release. these are almost GM generic, every FWD GM that i have paid attention to *should* have the same part. Quote
Garrett Powered Posted December 8, 2007 Report Posted December 8, 2007 AWeb80 said: Never Heard Of This Happening Before when you type like that it makes me think of william shatner Quote
