93CutlassSupreme Posted November 20, 2007 Report Posted November 20, 2007 Has anyone swapped in a more powerful brake booster? Quote
gp90se Posted November 21, 2007 Report Posted November 21, 2007 one of my only non complaints is the booster on these cars, curious as to why you'd want a "more powerful" one. Quote
Crazy K Posted November 21, 2007 Report Posted November 21, 2007 the 88 thru 93 boosters(+94 lumina)... SUCK! if you notice, the 94+ boosters are bigger in diameter and the same depth, which = better magnified brake force. I looked at a booster in a 00 Impala, it is longer than the earlier boosters, and about the same diameter as the early type. this would be a great candidate for a swap, as it uses the same retention method. Quote
93CutlassSupreme Posted November 21, 2007 Author Report Posted November 21, 2007 the 88 thru 93 boosters(+94 lumina)... SUCK! if you notice, the 94+ boosters are bigger in diameter and the same depth, which = better magnified brake force. I looked at a booster in a 00 Impala, it is longer than the earlier boosters, and about the same diameter as the early type. this would be a great candidate for a swap, as it uses the same retention method. Thank you Quote
Schurkey Posted November 29, 2007 Report Posted November 29, 2007 http://www.w-body.com/forum/index.php/topic,63764.0.html You don't need a BIGGER booster, you just need one that WORKS. Enjoy! Schurkey Quote
