alphagtp Posted November 16, 2007 Report Posted November 16, 2007 what do they do?? How much?? are they easy to install/remove?? are they worth it?? I'm getting a new/rebuild transmission pretty soon, can I have the shop install it for me? or would it mess with the warranty?? that's why the removal question, if something happens to my tranny and I take it back to the shop for the warranty, would it affect me?? ps I think this should be in Powertrain correct?? oopsy Quote
xtremerevolution Posted November 16, 2007 Report Posted November 16, 2007 what do they do?? How much?? are they easy to install/remove?? are they worth it?? I'm getting a new/rebuild transmission pretty soon, can I have the shop install it for me? or would it mess with the warranty?? that's why the removal question, if something happens to my tranny and I take it back to the shop for the warranty, would it affect me?? $40 for a big one. $20-$30 for a normal sized one. Add another $5-$10 for the fittings. Installation should take about an hour if you haven't ever done it before. It's fairly simple. Quote
pwmin Posted November 17, 2007 Report Posted November 17, 2007 what? do you mean a valve body shift kit? if its going to be rebuilt, theyll most likely use one anyway. Quote
RangeStang Posted November 17, 2007 Report Posted November 17, 2007 What! I have only found one and it does not do anything for performance just driveability stuff. If you have found one let me know. Quote
pwmin Posted November 17, 2007 Report Posted November 17, 2007 i'm assuming youre talking about the post before me. but, there is only one valve body shift kit for 60e's...transgo jr. (like you said, driveability only). you can, however, use an adjustable vacuum modulator for firmer shifts or a powrtuner (odb2 only) for higher shift rpm/mph's. the b&m gasket and electronic shift kits are pretty much worthless. Quote
