dohc v6 Posted November 16, 2007 Report Posted November 16, 2007 Ok so i got this nice new motor, but for some reason both of our rebuilds leak oil from the harmonic balancer. i checked and its not the pan gasket.I replaced the balancer at $200, not cheap and still no fix. i put rtv on it, still did not fix it. Do I need to have a sleeve machined so that it can slide over the pully. I replaced the seals on the timing chain cover so i dont think that its this. How do i fix this????? Quote
dohc v6 Posted November 16, 2007 Author Report Posted November 16, 2007 Its hard to tell where its leaking, but the seal is brand new, the whole engine is. I did not do a half ass rebuild. Quote
19Cutlass94 Posted November 16, 2007 Report Posted November 16, 2007 well theres only so many things that would cause this... most being the seal, oilpan gasket, or the RTV on the inside sleeve of the balancer and the keyway on the crank. I assume you used alot of RTV and you did let it sit overnight at the very least to set before you started it correct? Quote
pwmin Posted November 16, 2007 Report Posted November 16, 2007 they should make a repair sleeve for it. that might help. Quote
dohc v6 Posted November 16, 2007 Author Report Posted November 16, 2007 I did let it sit for about an hour not overnight. I am almost certain its the seal, I dont think its becasue of the rtv Quote
19Cutlass94 Posted November 17, 2007 Report Posted November 17, 2007 The RTV drying time is MUCH longer than an hour. Pull the balancer off, put fresh RTV on it and let it sit overnight. Im willing to bet thats your problem. Its the same reason that when doing LIM gaskets on the 3x00's you let it sit overnight cause of the use of RTV Quote
dohc v6 Posted November 17, 2007 Author Report Posted November 17, 2007 I will, and I will also replace the seal, just to mak sure Quote
Andrew Posted November 17, 2007 Report Posted November 17, 2007 The RTV drying time is MUCH longer than an hour. Pull the balancer off, put fresh RTV on it and let it sit overnight. Im willing to bet thats your problem. Its the same reason that when doing LIM gaskets on the 3x00's you let it sit overnight cause of the use of RTV X 2 !!! in an hour RTV is still very, for lack of a better word, not dry. Quote
z34duck Posted November 17, 2007 Report Posted November 17, 2007 yea for a repair like that you want to letthe rtv sit at least over night Quote
gp90se Posted November 18, 2007 Report Posted November 18, 2007 go get a can of "the right stuff" and let it cure for about 12 hours. I have never had that stuff fail on a simple oil leak. if the seal isn't seated right, no amount of RTV will fix the job Quote
BXX Posted November 19, 2007 Report Posted November 19, 2007 they should make a repair sleeve for it. that might help. Yup, and that's what he needs.... Along with a new seal, make sure to use a GM part or a Timken part... And quit usin RTV... RTV isn't gonna seal a crankshaft seal leak The crank has a seal for a reason Quote
dohc v6 Posted November 19, 2007 Author Report Posted November 19, 2007 Ok I will do this with the steerin rack. My car wont stop breaking Quote
BXX Posted November 19, 2007 Report Posted November 19, 2007 Hey, it's still teh hawtness though.. Im pretty sure once you get the quirks out you can finally have a lot of fun with it Quote
dohc v6 Posted November 19, 2007 Author Report Posted November 19, 2007 It is soo fun to drive. I have smoked so many cars, its rediculus. But thanks man for the help. I will let you know the outcome. Quote
dohc v6 Posted November 20, 2007 Author Report Posted November 20, 2007 ok what one shoud I get http://www.partsamerica.com/ProductList.aspx?PartType=925&PTSet=A Quote
dohc v6 Posted November 20, 2007 Author Report Posted November 20, 2007 Damn worked for me. Umm I went to advanceautoparts.com and looked up crankshaft seal and then i went to rockauto.com. Both have seals reanging from 8-40$ and they both have sleeves, but I just need to know what one to buy so that I can get these oil leaks fixed and move on to tuning. Quote
pwmin Posted November 20, 2007 Report Posted November 20, 2007 rockauto: does that have a GM seal? Fel-Pro should be fine. Quote
dohc v6 Posted November 20, 2007 Author Report Posted November 20, 2007 Uhhh, fel pro I used on the whole engine and for fixing all my friends cars, but damn I dont think they make a good oil pan gasket for the 3.4, I dont know though. Also I used the fel pro crank seal and its leaking. Any other brand that some one might suggest? Quote
BXX Posted November 20, 2007 Report Posted November 20, 2007 You need the repair sleeve... It's not the seals fault.... Quote
dohc v6 Posted November 20, 2007 Author Report Posted November 20, 2007 Can someone just tell me what the hell I need to buy Quote
dohc v6 Posted November 20, 2007 Author Report Posted November 20, 2007 Ok what sleeve do i need? http://www.rockauto.com/catalog/raframecatalog.php Quote
BXX Posted November 20, 2007 Report Posted November 20, 2007 Timken pn# KWK99298 or KWK99176 not sure which by discription It's about $50 and should come with a new seal as well... Quote
dohc v6 Posted November 20, 2007 Author Report Posted November 20, 2007 Are u 100% sure. They are 17$ right now on rock auto. If you say yes I will order it right now Quote
