3.1LUMITIC Posted November 15, 2007 Report Posted November 15, 2007 To start off this is on my moms 93 grand prix 3.1. The car started dying everytime it came to a stop and progressivly got worse by the hour, until it would not even run anymore. It does not hesitate, no shudder, just straight dies whenever you come to a stop. I unplugged the egr and the car runs fine. I have tried unplugging the tps and then plugging the egr in, no difference. Then i unplugged the iac and plugged the egr in, still same problem. I am getting 14 volts from the power wire that plugs into the egr. Cylanoids on the egr are all working properly, tested with a 9-volt battery. I am getting a code 22 after i unplugged the tps and plugged it back in, and a code 32 of corse because i have the egr unplugged. Before all this started happening it gave me code 33 and i replaced the map sensor and the code went away. Please anybody Help. -Matt Quote
Psych0matt Posted November 15, 2007 Report Posted November 15, 2007 have you cleaned up your egr at all?I would take all the valves out and soak them in brake cleaner, clean them off well, as well as spray a bit into the housing, and then see what happens Quote
3.1LUMITIC Posted November 16, 2007 Author Report Posted November 16, 2007 yes ive cleaned the egr and changed it with a different one. also will an brain for an 90 lumina with vacuum tranny work on an 93 grand prix elec tranny? Quote
Crazy K Posted November 16, 2007 Report Posted November 16, 2007 yes ive cleaned the egr and changed it with a different one. also will an brain for an 90 lumina with vacuum tranny work on an 93 grand prix elec tranny? NO. it does not have the right circuitry to operate the transmission. Quote
