96gpallday Posted November 14, 2007 Report Share Posted November 14, 2007 i have a 96 gp. it was running fuckin tits for about 4 days best its ran sence i got the car but then on monday i parked it came back 3 hours later and my battery was dead. so i juped it and thaout it was my altinator so i kept it at a hgih rpm so my batt would charge but when i turned the lights on the car just shuts down. and when i turned the lights to the off position they turned on and my alarm statring making noices its never made. so i jumped it again but when i turned the lights on my sterio would turn noff and all the lights would dim so i turned it off again re jumped it and kept it a steady 2000 rpm then my car jus completly shuts down and wont turn over. none of the lights work not evan when i openthe door evan with a new battery in it. i got the starter and the alt. checked theyre both good. i followed the battery lines there good i chcked the ground tand there good but still nothing. im worried i fried my computer. and i need any suggestions be for i do anything els. Quote Link to comment Share on other sites More sharing options...
Bake82 Posted November 14, 2007 Report Share Posted November 14, 2007 Check your AUX post. Make sure that is good and tight. Besides that I don't know....but double check that. Quote Link to comment Share on other sites More sharing options...
Guest alpahgtp Posted November 14, 2007 Report Share Posted November 14, 2007 X2 on the Aux post, is not, maybe you need a new alternator... Quote Link to comment Share on other sites More sharing options...
19Cutlass94 Posted November 15, 2007 Report Share Posted November 15, 2007 check the AUX?! check the spelling and grammar! Quote Link to comment Share on other sites More sharing options...
96gpallday Posted November 15, 2007 Author Report Share Posted November 15, 2007 i checked the post and everything is tight i finally got sometime so i put it backto gether today and i jumped it but as soon as i put it in gear it shut down again. ima jus go out and bye another battery evan tho my other one is only a month old! but hopefully that takes care of takes care of the problem but for some reason i dont think it will. thanks for the help tho Quote Link to comment Share on other sites More sharing options...
5speedz34 Posted November 16, 2007 Report Share Posted November 16, 2007 What engine is in this car? Quote Link to comment Share on other sites More sharing options...
boulevard Posted November 16, 2007 Report Share Posted November 16, 2007 Did you get the new battery in it yet? Has your car run any better yet? Get your alarm module checked out. Sounds like a mess. Quote Link to comment Share on other sites More sharing options...
5speedz34 Posted November 16, 2007 Report Share Posted November 16, 2007 My guess is you killed your alt, since it sounded like your battery was/is and that killed the alt. I would take it somewhere and get the charging system tested. Do you have alot of audio/aftermarket stuff running? Quote Link to comment Share on other sites More sharing options...
Q-Ball Posted November 17, 2007 Report Share Posted November 17, 2007 I'm guessing its a 3100. GTP's dont have door badges. Quote Link to comment Share on other sites More sharing options...
96gpallday Posted November 17, 2007 Author Report Share Posted November 17, 2007 yea i got the new batt. in and is runing now but the post that goes into the starter wear my power line goes is loose so my starter is shot and i dont have the $$$ to get a new one yet so i got to pop the hood and shake it every time i got to start it . but yea it is a 3100 but hopefully bye this spring it will be a 3800 super charged . and yes i also have an after market stereo system two twelves w/amp,headunit,new6x9s, new doors speakers and tweeters coming soon to. Quote Link to comment Share on other sites More sharing options...
boulevard Posted November 17, 2007 Report Share Posted November 17, 2007 Where are you located? Quote Link to comment Share on other sites More sharing options...
94CutlassXtreme Posted November 17, 2007 Report Share Posted November 17, 2007 Sounds maybe like the starter wire was corroded and shorted out a few things. I'm guessing the lights won't turn on because you popped a few fuses. Quote Link to comment Share on other sites More sharing options...
B_A_Buick3.1 Posted November 20, 2007 Report Share Posted November 20, 2007 Sounds maybe like the starter wire was corroded and shorted out a few things. I'm guessing the lights won't turn on because you popped a few fuses. I agree wit him, it sounds like a straight to ground short, either at the starter or the batt. itself, and that can really f*ck things up wunderfully for you.... anyway hope things work out 4 ya... Quote Link to comment Share on other sites More sharing options...
